0 Members and 356 Guests are viewing this topic.
apecore
Quote from: Dog-One on April 17, 2016, 03:02:53 PM
Seems to me this would be an interesting device (coil/capacitor) to expose to a high voltage e-field as shown in the first Roma Grits video.  Notice in that video there is no "apparent" connection between the main secondary coil and the adjacent "pickup" coil connected to the "capacitor" (unknown device under the coffee cup) and output load.  Likely such a composite device could be directly connected to a load.
I'm still experimenting with low power, high frequency stuff at the moment, but as I get into the range of blowing electronic appliances up, I may have to take some time to wrap such a coil/capacitor device and see what it does.
BTW Verpies, that coil I wound and mentioned a while back, it loves to run at about 2.5MHz and is a little tricky at the moment keeping a MOSFET Kacher out of the Miller range--runs a tad hot.
Thanks Dog-one for the respond,
I hope you have read the attached pdf file i linked in my latest quote, there's a lot explanation about it.
Let me know when you will start winding and testing such a TBC , i have some experience in dimensions and capacity etc.
I am setting up a experiment myself.
Use if you want my PM.
Succes
Zeitmaschine
Quote from: verpies on April 17, 2016, 09:26:33 AM
Yes, but only with brass and soft steel disk combos ( mine were 30cm OD and AFAIK TK's were 50cm OD ).
I blew up my scope while working with it and quit.
Sorry, have to ask another highly intelligent question: How do we know for sure that the steel disc is made of steel indeed and not aluminum? In that blurry video the silver color would be the same. Does Kapanadze say himself that it is steel?
Grumage
Dear Zeitmaschine.
Your transformer looks like it could have been a 3 phase welder.
Hmmmm...... Three " Daniel Macfarland Cook " coils on a common core!   ;)
Going back I spent nearly 2 decades with the supply industry, UK. Aluminium was all the rage, it was lighter and cheaper than Copper. Jointing was done using special flux and an ABR bar. This Lead bar contained an abrasive material that scrubbed and tinned simultaneously. It seems that crimping has become the norm these days. As for Aluminium transformer windings they were also quite common, after all, they used bolted connections!
Cheers Grum.
Zeitmaschine
Dog-One
Quote from: a.king21 on April 18, 2016, 04:57:13 AM
Air contains: radiant energy, static, radio frequencies. Think! man.
I am. I am.  I just can't see what I'm looking for inside this box.
What I do see is a lot of standard electronics, a relatively normal transformer and no ground wire.  No antenna and even a metal box for shielding.  So if there is a trick to it, it must be timing.
What is it really that Kapanadze knows?  Something he has never told anyone?
Oh wait, I know how much Nick hates seeing electronics in a box.  This is better.
I'll say it before someone else does:  There is a battery inside the fake core of the transformer.  There, now everyone is happy.
