0 Members and 47 Guests are viewing this topic.
T-1000
Quote from: Dog-One on April 18, 2016, 02:21:18 PM
I am. I am.  I just can't see what I'm looking for inside this box.
The revealing main components are in the PCB underneath, also seen another video.
It reminds me never ending flashlight experiments.. :) Which was extensively discussed on other threads.
Cheers!
Void
What I do see is a lot of standard electronics, a relatively normal transformer and no ground wire.  No antenna and even a metal box for shielding.  So if there is a trick to it, it must be timing.
Here's another device along those lines.
https://www.youtube.com/watch?v=D4IkEE2Mbkc
Yes, I know there could possibly be batteries hidden in the heat sinks at the bottom... ;)
Void
Quote from: Jeg on April 18, 2016, 11:18:40 AM
I have some problems on finding a good rectifier output bridge. I need some economic and quick diodes at 1000V @10A minimum specs. My old bridge consist of 4X RURG3060 was blown. Accidentally i disconnected my loads while running and output voltage was raised over 600V which is the maximum for these diodes. Any idea?
Hi Jeg. The digikey.com website is good for finding parts that meet certain
minimum specs which you specify. For example, here is a list of fast recovery diodes
which are minimum 1000V reverse voltage and a minimum of 10A current rating:
Fast recovery diodes list
verpies
Quote from: Zeitmaschine on April 18, 2016, 12:40:23 PM
Sorry, have to ask another highly intelligent question: How do we know for sure that the steel disc is made of steel indeed and not aluminum? In that blurry video the silver color would be the same. Does Kapanadze say himself that it is steel?
We don't know for sure.
I am not aware of TK saying anything about the composition of these disks.
verpies
Quote from: Zeitmaschine on April 18, 2016, 08:25:13 AM
On a blurry video we can »spot« fakes that no one on location was able to see.
We don't know the observational powers of the "inspectors".  Not everyone is as observant as Hoppy.
If one turns the discs by hand (could easily happen) he should feel when there is a belt connected to a hidden motor.
Maybe and maybe not.  There are some smooth belts out there and belt is not as noisy and rough as a chain.  Also an unpowered squirrel-cage AC induction motor does not exhibit any cogging when spun manually.  Anyway, a 20kg disk has so much inertia, that it will mask a lot of torque ripple.
And I doubt that phase induction coils at a few centimeters spacing can convey that much power so the large generator next to the discs can be driven.
Yes, the mechanical power of such coils at that distance would not be great but it would be sufficient to spin the unloaded shaft with disks on it.
With the aid of x-wires, the generator could always turn out to be a motor.  In that warehouse nobody was smart enough to compare the belt tension under the pulley to the tension over the pulley, in order to determine whether the shaft with disks is propelling the "generator" or the "motor" is propelling the shaft with disks.
Quote from: A.King21 on April 18, 2016, 04:24:34 AM
He  wanted to build us a mechanical device and I told him no.
I wonder how much money a demo of such device costs today?
Can you ask him?
