0 Members and 277 Guests are viewing this topic.
verpies
Quote from: Void on April 18, 2016, 03:53:47 PM
Here's another device along those lines.
https://www.youtube.com/watch?v=D4IkEE2Mbkc
Yes, I know there could possibly be batteries hidden in the heat sinks at the bottom... ;)
The spaces between the ribs of the heat sink are visible, so that minimizes the volume which could be used to hide batteries.
Anyway, all that would be needed to dispel any suspicion of batteries, would be a longer video runtime :(
Zeitmaschine
Quote from: verpies on April 18, 2016, 06:55:34 PM
We don't know for sure.
I am not aware of TK saying anything about the composition of these disks.
The question here is (if the disc device is real) what is the electric difference between brass and aluminum? Why two different metals?
What is Electronegativity?
Electronegativity attract electrons.
»The higher the associated electronegativity number, the more an element or compound attracts electrons towards it.«
»The opposite of electronegativity is electropositivity: a measure of an element's ability to donate electrons.«
According to the table below, copper (brass) should attract electrons from aluminum. So the aluminum is positive and the copper negative. The difference between copper and aluminum is greater than between copper and iron (steel), thus the silver disc should be aluminum (IMHO).
Why not a steel and a aluminum disc? Because steel can be magnetized (maybe that's bad) and a disc made of stainless steel is a not so good conductor?
Anyway, why electronegativity should make the discs rotate stays a mystery (for now).
Regarding the transformer device: A copper transformer generates high voltage and is connected to an aluminum transformer (or choke), would that mean that it could attract electrons from an aluminum coil more easily than from a copper coil?
What could be the advantage of that?
verpies
Quote from: Zeitmaschine on April 18, 2016, 08:40:45 PM
You can put an electrolyte between aluminum and copper sheets to make a chemical battery and generate some electric current, but not enough to light up 100W incandescent bulbs or rotate that shaft.  At least not without several km2 of surface area.
AFAIK the soft steel disk guides the magnetic field, created by the magnets&coil on the shaft between the disks, in order to uniformly penetrate the copper/brass disk.
Dog-One
Quote from: verpies on April 18, 2016, 07:27:41 PM
What is needed is someone to come forth and explain exactly how you agitate "The Ambient Background", then collect that energy in quantity exceeding what was used to create the initial agitation.
With hundreds of such videos floating all over the internet, surely one of them is real and surely somebody knows how it works or how at least to make such a device work.
WHERE ARE YOU OH GREAT CREATOR OF LIGHT ? ? ?
Please show yourself and put an end to this madness.
Jeg
Quote from: Void on April 18, 2016, 04:10:26 PM
Hi Jeg. The digikey.com website is good for finding parts that meet certain
minimum specs which you specify. For example, here is a list of fast recovery diodes
which are minimum 1000V reverse voltage and a minimum of 10A current rating:
Thanks a lot Void, T1000
This output bridge is one of the main factors that determine the output high frequency response. When i changed from my previous bridge to what i am currently using, i had to re-tune my coils! I think that Ruslan already had mentioned this as a negative factor. Anyway. Still experimenting on this :)
