0 Members and 445 Guests are viewing this topic.
NickZ
   Zeit:
   You'll have to ask Nelson concerning the switches that you see. As we don't know just how he has everything wired, nor has he  provided any schematics, or detailed instructions concerning it's operation.
  You had mentioned a "switch connection" at the rectifier, previously, and I answered that I see no switch there, just tuning caps similar to what Geo has done.
   You also asked why we need more than the standard 50 hertz rectifier when dealing with the conversion of Aether to use able power, such as to run conventional devices. Because the Aether is not running at 50 hertz frequency like the grid is.  And conventional full bridge rectifiers can be limiting the available energy that can be be tapped from it.  But, the main reason is that the normal full bridge rectifiers will overheat, at higher output. And is also one of the limiting factors in the output of such devices, especially for the devices with higher kw outputs.
  Possibly Verpies can best answer some of those questions, in a conventional way.
   The thing that I see in ALL of these type of self runners is, that they all are using an impulse circuit of one form or another to create an impulse wave that will affect the surrounding ambient. And there are three things in common with all of those circuits. They all require coils, capacitors, a spark gap (or a solid state circuit) to create and extract the Aether, then convert it to use able energy.  Although many people will still not believe it, as we have been taught, even to this day, to disregard all this as just nonsense.
nelsonrochaa
Hi , only to stop with speculation about what make the switches because some of the things that i ear bit some strange  to so qualified people  :)  :
Number 1 short system oscillation circuit to stop the circuit .
Number 2 is even not connected (box are salvaged and that switch prevent original circuit work when top is opened )  but not used to nothing.
Number 3 not short anything only able to activate one particular item in circuit to provide double of voltage output about 600v.  (in the video i show that )  when run the motor.
about  Bridges are convencional 50hz and are not connected directly in  the output transformer  , but in  step down stage, in main storage capacitor  so , i never destroy anyone of the bridges, even i know not the best bridges to use but is what i have available in that time  .
About put my fingers without take a pummeled  :) :
The output that Doug talk is 32v so no "blim" but even the high voltage output without have  the step down stage and stored in the cap output don't give "blim" too ;
of course after stored in cap will be letal for sure . but we will not letal if we learn to control  and it not stored in  capacitor . One year ago
https://www.youtube.com/watch?v=Is9fOtBeo_I is one of the stages used in the main box  that could be find in the photo . If someone are really  interest see all the video and what i show and  will see that i not get pummeled  even with voltages around 800v rms.
  In the channel  the people interested will   find all the stages until i reach that box month to month ,  until i stop put videos is like a book , but most only search the GOLD and forget the work behind....
I start with nothing ! just work with lab work without equipment and material only search  to old pcb to salvaged components .
I was not born in a golden cradle and even that with cunning and ingenuity adapted the materials he had. but most of people have almost resources and even that only teorize . GO WORK TO BENCH  !
Void
Quote from: nelsonrochaa on April 19, 2016, 06:23:12 PM
Hi Nelson.  Aye, high voltage AC in the high frequency range (above about 10 kHz at the least) is more apt to cause skin burns
than big shocks, although in some cases it can cause shocks as well. The higher the current capacity, the higher the risk
of shocks. The output of lower power tesla coils can be several thousand volts but the current capacity at the high voltage
end of the tesla coil secondary is relatively small if the HV end of the secondary wire is contacted directly. It all depends on how
you are taking the output off of the high voltage coil or transformer however. I have received shocks from the battery terminals
of a kacher driver in some cases, as the battery is getting fed back with higher current at high enough voltages to cause shocks
from the 'grounded' end of the tesla coil secondary. People who think that tesla coils and other high frequency HV devices can't give
shocks may be in for a big shock someday (pun intended). ;D It is very much about current capacity at the point in the circuit you are making
contact with, and how you are making contact with your body.
nelsonrochaa
Quote from: Void on April 19, 2016, 06:37:24 PM
Hi,
I know about that points that you refer like the feed back ;) i already burn a power source because that .And you could see how much is return to power source in the second channel :) even disconnected . The important thing that you tell :
you are taking the output off of the high voltage coil or transformer however ;)
Zeitmaschine
You are sure there is no hidden battery anywhere in the box?
And all those components are really needed in order to make it self-running?
Wouldn't it be more straight forward to provide a plain schematic?
Quote from: NickZ on April 19, 2016, 06:11:37 PM
A catchment lake is also not running at 50Hz, nevertheless it is possible to get electric current at 50Hz out of it.
