0 Members and 25 Guests are viewing this topic.
nelsonrochaa
Quote from: Zeitmaschine on April 19, 2016, 06:50:04 PM
You are sure there is no hidden battery anywhere in the box?
And all those components are really needed in order to make it self-running?
Wouldn't it be more straight forward to provide a plain schematic?
A catchment lake is also not running at 50Hz, nevertheless it is possible to get electric current at 50Hz out of it.
About you first question :
i don't have sure a,bout that lol  but you have ;)
If all that components are need ?
Not all but in that time i think that ever component is need and the box is small to put everything , ;)
About a schematic  :
you really are a joker   ;) but i like persons with sense of humor .
about your last question :
If you say ... that's ok i will even discussed that with you is not my goal is your goal !
Good luck
a.king21
Nelson:  It looks  your HV is created by a HV module.
In other words a HV module you can by from China?
Is that correct?
Zeitmaschine
Quote from: nelsonrochaa on April 19, 2016, 06:59:39 PM
This looks somewhat over-complicated to me. Kapanadze generates 5KW out of a small tin can without sophisticated electronics. Maybe you doing something wrong here since you need all these parts for less than 5KW?
NickZ
 So, Nelson,  I "go work to bench"... and find that I'm able to reproduce your effects just now, on my Kacher/grenade circuit (without the induction circuit connected). The only thing that I can't do is to have no current flowing from my PS, as it's not adjustable.
In any case, I was able to light a 10w incandescent bulb between the aluminum sheet (placed on top of the antenna coil), and the earth ground. Which I can't do otherwise. As I'm using a not adequate weak transistor on the Kacher circuit now, until I can get the right one.  I was also able to light a neon bulb, and CFL bulb. I'm looking for my 20w 220v microwave bulb now, to try that next.
  I'm always grateful for ANY information that you can provide.
   BTW: I've seen most all of your videos, and some of them several times. I can also understand your language to some degree, as I also can speak Spanish, and there are many similarities as both languages are Latin based.
   Thanks again,
                        Pura Vida,
                                         NickZ,
                                                   Costa Rica.
NickZ
Quote from: Zeitmaschine on April 19, 2016, 07:40:31 PM
   Or he's doing something very right, as he is using no current to do what he has shown, only fluffy voltage.
Unlike TK with his big car battery, and inverter, etz...  Just how many components do you think are in that inverter, alone?
   Look at the simple Kacher circuit that can generate kWs (made by Roma), using NO external input source, nor any ground.
That is the direction this all can take. But, the first thing is to obtain the amplification "effect".
