0 Members and 1096 Guests are viewing this topic.
Dog-One
Quote from: NickZ on April 19, 2016, 10:14:19 PM
However, it looks like the capacitors are what separates the positive from the negative, from the Aether, so that it can be made to work with our normal electrical devices.
From what I can tell so far, capacitors should not be charged while connected to a load.  Doug Konzen made this explicitly clear.  One can rectify a sine wave source (coming from Aether vibrations, specifically sympathetic Aether vibrations) and charge a capacitor.  The capacitor is then dumped to a load at regular intervals once it is charged sufficiently.  Once dumped, the capacitor is disconnected from the load and recharged.  The higher the frequency of the vibrations, the faster you can recharge the capacitor.  Kilohertz will probably work; megahertz will probably work better.  Schottky diodes are plenty fast for megahertz work.
What Nelson was showing us in that video, is that Aether disturbances are all over the place from the simple low-power driver he was using.  If you collect these disturbances in the right place (no inductive association with the exciter), you can add as many of them as you want.  And if your exciter is truly efficient, it should take almost zero amps to run it.  Then everything you collect is gravy.  What we need to pay attention to is how to collect the Aether disturbances without an inductive link back to the exciter.  If you do it wrong, the exciter output will drop and its input will begin to draw more amps.
Back to the bench...
M@
nelsonrochaa
Quote from: a.king21 on April 19, 2016, 07:32:17 PM
Nelson:  It looks  your HV is created by a HV module.
In other words a HV module you can by from China?
Is that correct?
Hi a.King21 no  is not correct . Every stage is designed by myself , since the very first detail you could see is pcb proto , i call modules because in that time i "join" all the parts and each one have their application .
cheers
nelsonrochaa
Quote from: Zeitmaschine on April 19, 2016, 07:40:31 PM
This looks somewhat over-complicated to me. Kapanadze generates 5KW out of a small tin can without sophisticated electronics. Maybe you doing something wrong here since you need all these parts for less than 5KW?
Could be complicated to you understand , something that you never see run alive  this way you talk like you have already find your own "goal" but seems not .
What sophisticated electronics you find only by a picture  ?  some transform , some home coils and  caps made by myself  and my pcb is that to you call  sophisticated ?
So if you see what i work at moment you will simple run run away... lol
Now you become arrogant too ! you say that maybe i made something wrong , because in that demo i use so much components to output less 5KW ... this is a comedy ? or tragedy? :)  Better you find kapanadze to you ask them by exactly details ... if he could give that information !
I deal with true things not with suppositions if work  or if are true,   bu you t to someone that want to learn , that arrogance that you show  only will conduct you to nothing ... nicles
seychelles
Can somebody please enlighten me in block diagram how this thing is suppose to work..
Zeitmaschine
Quote from: nelsonrochaa on April 20, 2016, 02:29:08 AM
I'm just wondering if we deal in each and every case with the same phenomena!
Tesla 1931 and Moray 1936 worked with an antenna. Kapanadze, Stepanov and Barbosa do not. How can that be?
So I would guess we deal with principle #1 when high voltage (and ionization) is involved and thus an antenna is needed and we deal with principle #2 when only ground is needed without an antenna and without high voltage.
It looks like this is causing a lot of confusion. We have (at least) two different types of devices mixed up. The high voltage device works via an electric field and the low voltage device via a magnetic field. Because when an arc welder makes a meter running backwards I can't see how it could generate high voltage anywhere. The high voltage supplying Kapanadze's spark gap is just a decoy, though.
Quote from: yfree on April 19, 2016, 10:25:10 PM
This very effect is used in DALLY FREE ENERGY device ...
Then likewise you do suggest that there is more than one Modus Operandi for such devices?
I'm not convinced that DALLY is real because I'm very suspicious about such one-man (or even two-men) videos showing self-runners, as I mentioned before. So what tells you that the DALLY device is real?
