0 Members and 39 Guests are viewing this topic.
apecore
Quote from: AlienGrey on April 20, 2016, 07:16:41 AM
Imagine a scenario where we have a power charger accelerator that charges a C, when C is charged it takes T time, C is then fired into a coil L , ...... T and C and L are resanat circuit, wouldn't that create free energy ? Like kicking a football with the wind ;)
Is this what you mean?
When the capacitor discharges across itself to become a parallel L/C circuit, the induced rotating electric field (with the help of negative energy) creates a difference of voltage between adjacent plates, this voltage according the Gauss law causes new electrons to be present in the system.
If we connect a spark-gap between point C and point D, then the negative energy will be drawn into our system with the same speed as positive energy! The symmetry between the magnetic and electric sides in our positive energy reality will open the correct door for the undetectable negative energy reality!
Initially, when the capacitor starts to discharge, the current increases but the induced rotating electric field will tend to keep the voltage at a high value. The capacitor discharge through the spark-gap (which requires a large amount of voltage), the current flow does not start immediately. Initially, the current increases but the spark does not occur. This pushes the voltage up higher (behaviour which is known in parallel L/C circuits), then the current increases to a high value very quickly, while the voltage is drawn down to a level which cannot sustain the spark. When the capacitor is totally discharged the current flow through the spark-gap is at its maximum value. Consequently, the extended Tesla Bi-filar Coil produces a square wave rather than the expected sine-wave which is produced by an ordinary parallel LC circuit. The square wave produced when the spark occurs, contains waves of all frequencies and so, even if the time during the spark is short, there will still be thousands of oscillations in that time. I know that it is not easy to visualise this, but it is what actually happens.
This special genius design solves the most difficult problems in cold electricity, due to it's reversed behaviour compared to hot electricity. Cold electricity prefers to flow along materials which we consider to be insulators while hot electricity prefers to flow along materials which we consider to be conductors.
According Tom Bearden, with negative electricity the capacitor performs in the way that a coil does with hot electricity, and the coil will perform like a hot electricity capacitor.
The question is how are connecting this?
a.king21
Quote from: Zeitmaschine on April 20, 2016, 07:40:17 AM
Clarence: »my name is just a DIRTY WORD to the majority of the members so I just took my success and left and quit posting.«
I wonder what the reason for that could be?
short I knew how to build their unit AND DID! no one else could or did!
Because - if he did it - he does not supply enough information to others for replication?
Then their device is a scam or just a simple measurement error?
Clarence is still posting on the Energetic forum and others are replicating.
Quote from: Zeitmaschine on April 20, 2016, 07:40:17 AM[/size]
I have posted three times the video link already.
This is to do with reactive power. A modern meter will compensate for it.
Here is something to try:  the CFL bulb scam.
Use a watt meter to measure the consumption of a cfl bulb.
You'll find it is DOUBLE the consumption claimed by the manufacturers.
ie an 18 watt cfl will consume 36 watts.
Power factor again......
Zeitmaschine
Quote from: a.king21 on April 20, 2016, 08:25:29 AM
Successfully replicating? If Clarence has a working simple device it should be also simple to replicate it - not taking months or years.
How do you know? What is the difference between a meter running backwards because of reactive power and a meter running backwards because of additional generated power pushed into the grid? How do we tell this apart?
NickZ
AlienGrey
ie an 18-watt cfl will consume 36 watts.
is this true or a joke ? I know if you have a 4ft tube is 35 watt  and ballast the ballast will wast another 10 watts I wonder if its the same trick. Also the new Smart meter racket, it's put in for free but then your tariff goes from 18 p to 28 p pluss all your appliances are broadcasting microwaves all around your house and transmitting it to a central point !
