0 Members and 18 Guests are viewing this topic.
NickZ
    T-1000:
    We're waiting for you to show us what you've got going, and how well it's been working out.
    Geo's still having problems, and the rest of us are stuck on obtaining no extra energy from any of our devices.
    Tomtech, Itsu, Void, etz... as well as myself would like to see something that works.  As so far,  it's still  no cigar.
    Akula, Ruslan, or Nelson aren't telling all their secrets, as yet, either.
    I tried to do what Nelson has done in my own way, but, I can't run my Kacher on 11v, and no current.
    So....
    It may be time to replicate a simpler but supposed working self runner. Like the Roma device.  If we only could.
    Too many secrets still.  And so, No One has replicated the Ruslan devices, to work as they should.
Not good...
Hoppy
Quote from: NickZ on April 22, 2016, 09:20:29 AM
Not good...
Nick,
Have you tried the simple Joule thief type circuit you posted from Nelson earlier? This maybe be a better way to progress as Nelson did. Kapanadze's / Ruslan's  methods of operation may not be the same as Nelson's, so there maybe at least a couple of ways to skin the cat.  :) I'll probably knock this one up for experimentation when I've completed my current electronics work project.
AlienGrey
Ok i have an idea the katcher outer coil 6 turns ok know what I'm talking about if you put say 3 or 4 kv static charge on it and the zero feed down to earth you would have 3 kv more than the earth around that coil environment and spark gap it in phase, have you got that ? now the katcher coil run that at 1.5 mhz like a transmitter and your grenade coil at 150 kh phase locked. then try it !
NickZ
Quote from: Hoppy on April 22, 2016, 10:38:55 AM
Nick,
  Hoppy: I see that the Roma device can crank out kWs of power, from a very simple Kacher circuit as the pulse circuit source.
If true.  So, I'm intrigued by that device and it's simplicity, along with it's outstanding output.
   I'm also intrigued by the way that Nelson's device can work on NO current, and still produce a useable although more limited output. And even self run, while lighting some bulbs, motors, etz...  However, it does requires a much higher component count to work, compared to the Roma device, but uses fewer coils. Or at least not as big. Maybe the reason of it's lower output, compared to Roma's device.
  So, I'm still tossing all this around, while playing at the bench, but getting no where, fast.
  And, as Nelson wants to keep the main secret of it's mode of operation, a secret still, he offers no more hints. ..
  What can I  do?  I'm still looking for the "amplification effect", which can also be adapted work with the Ruslan/Akula device.
Void
Quote from: NickZ on April 22, 2016, 12:08:00 PM
Hi Nick. The built-in ammeter on Nelson's bench power supply has a resolution of 10 mA, so
when that ammeter reads 0.00 A, the current can be anywhere from 0 to 9.99 mA. Nelson's
circuit is probably still drawing some current when the ammeter on his power supply reads
0.00, but all we can tell from the power supply ammeter when it is reading 0.00 is that it is
less than 10 mA.
