0 Members and 23 Guests are viewing this topic.
nelsonrochaa
Quote from: NickZ on April 22, 2016, 05:34:54 PM
  Nelson:
  What do you mean by "open primary"?  How do you connect your primary coil, so it's open?
   I see the difference is that the video showing the lighting of the different bulbs, requires more input, that it obtains at the output, in lumin levels of those bulbs. So, it's not efficient when using it as a Kacher circuit, and can be more efficient as an Exciter, instead.
  But, don't the Exciter circuits have a lower output limit, as well, compared to the Kacher circuits.
Hi Nick ,
You could see clearly that Tesla coil don't have primary is not visible in the shot video that i show? is not magnetically coupled .
Stela show a Tesla coil with a primary  closed wind   like usual is used  ;
in a normal transformer you have a primary and secondary coupled magnetically and primary induce in secondary ;
My Tesla coil in the video don't have  that primary ! understand now ?
About  the output of that circuit : Is only a circuit tool to study like others circuits that i show , is  not designed to output several power output but to study !  I make my own circuits based in small scale ever time but all that circuits after be understand could be scaled to more output, but to do that first need to understand the concepts or not ? ;)
Void
Quote from: Stela on April 22, 2016, 05:19:32 PM
According to my results, the most viable path is Ferroresonance.
Here there in that air coils without semiconductor.
https://www.youtube.com/watch?v=IAk6jnEh6Rg
And the same effect but here with ferrites :
https://www.youtube.com/watch?v=szq5lX-9Hm0
Good luck .
Hi Stela. Did you have your signal generator going through a power amplifier to the coil in the
ferroresonance tests you referenced above?
P.S. Some of what you showed in your videos may possibly be due to the 'Barkhausen Effect', but I
am not sure about that.
https://en.wikipedia.org/wiki/Barkhausen_effect
Hoppy
Quote from: nelsonrochaa on April 22, 2016, 03:54:31 PM
Hoppy:
Why do you think the circuit is a "simple" joule thief? It's not even comparable!
Simple is you think that! I worked immense months in  this circuit observing all possible and impossible points scrutinizing every detail in order to understand certain aspects that were crucial to advance.
Nelson,
I'm not arguing that you have discovered something important. The circuit you posted some time back looks like a Joule Thief to me but apologise, as I accept that it is not simple, as there are some interesting additions, such as C2, C3 & C4. As I suggested to Nick, he should experiment with this circuit as I intend to do.
You say that you do not use a closed loop primary, so that is something we can ponder over.
a.king21
I am experimenting with  slayer and it is very economical. However I understand what Nelson is saying. If the primary is looped then you have induction and use a lot of power. If we can get it to work using single wire then the amp draw is minimal.
However experimenting this way is gonna blow  lot of transistors maybe...
Void
Quote from: a.king21 on April 22, 2016, 06:33:30 PM
Hi a.king21. Yes, I think some of what Nelson has been showing has similarities to the
Slayer Exciter and SEC type setups, as near as I can tell anyway.  :)
