0 Members and 99 Guests are viewing this topic.
AlienGrey
Quote from: nelsonrochaa on April 22, 2016, 05:47:15 PM
Hi Nick ,
You could see clearly that Tesla coil don't have primary is not visible in the shot video that i show? is not magnetically coupled .
Stela show a Tesla coil with a primary  closed wind   like usual is used  ;
in a normal transformer you have a primary and secondary coupled magnetically and primary induce in secondary ;
My Tesla coil in the video don't have  that primary ! understand now ?
About  the output of that circuit : Is only a circuit tool to study like others circuits that i show , is  not designed to output several power output but to study !  I make my own circuits based in small scale ever time but all that circuits after be understand could be scaled to more output, but to do that first need to understand the concepts or not ? ;)
I'm not trying to be funny but can some one please show what Nelson is saying here cus i'm just as wise reading it as not  ;)
AlienGrey
Quote from: Void on April 22, 2016, 06:46:30 PM
Hi a.king21. Yes, I think some of what Nelson has been showing has similarities to the
Slayer Exciter and SEC type setups, as near as I can tell anyway.  :)
SEC don't you need a spectrum analyser for that to find where the peaks are in order to tun to them and exploit them ?
Void
Quote from: AlienGrey on April 22, 2016, 06:58:48 PM
Hi AG. I don't know a whole lot of detail about the SEC setups, just watched some of the videos.
I wasn't convinced that the circuits weren't just powered at least in part by EM fields surrounding
the mains connected bench test equipment or other EM noise. There could have been more to it than that,
but it was such low power that it is hard to tell. I have run a blocking oscillator at very low power level powered only from
the voltage differences of induced mains line voltage that couples into my scope ground and my earth ground wire.
The SEC did seem to produce more power than that, so there could well be more to it than just surrounding EM field
pickup.
a.king21
Yes, but what Nelson is saying is make the slayer or a similar exciter work  without induction in the primary.
I know avramenkos will work but I do not have the equipment to see if an Avramenko increases current draw on the primary.
Void
Quote from: a.king21 on April 22, 2016, 07:18:31 PM
Right, I understood that when Nelson mentioned that the first time a few weeks ago.
I have experimented with that sort of setup a fair bit already in the past, so I was already familiar with
the concept. Trying to use that approach to make a self running circuit is probably a lot easier said than
done however, but I am working on it along with investigating other approaches and ideas as well. :)
