0 Members and 779 Guests are viewing this topic.
lost_bro
Quote from: Dog-One on April 23, 2016, 07:04:09 PM
Watch this video carefully:
https://www.youtube.com/watch?v=tDh7Uw5XC_w
That is 1600 volt peaks, rectified unipolar pulses. Single wire, no closed loops, therefore amperage is flat zero, no electron flow and no magnetic field, purely electric agitation of the Aether.
Now think about the classical electromagnetic model.  Remember it?  The red sine wave and 90 degrees to it the blue magnetic sine wave.  Completely yank the blue magnetic sine wave out.  It's gone.  Actually it was never created.
So we have a purely electrical disturbance of the Aether.  Here's where things become rather humbling...
You all remember Lenz Law right?  That thing stopping us from our dreams.  Ha!  Lenz Law is a godsend and here's why...
When a purely electric disturbance interfaces with a load (lamp, coil, motor, whatever), what happens?  Lets take the case of a coil connected to a lamp to make it easier to visualize.  Suppose the coil begins to vibrate from the electric field we have created.  Does it not generate a reverse magnetic field to counteract the magnetic field inducing it?  But we have no magnetic field inducing it, so there's nothing for this magnetic field to butt heads with.  Lenz says it will be reversed, in opposition to the field.  We do have a field, but it's only electric.  Add it up, or better said, multiply it out.  You have an electric component (voltage) and a magnetic component (amperage).  That would be watts my friend, real power.  We didn't have to do anything but walk into the room and Lenz created us a magnetic field to go with our electric field.  Could it be any more simple?
Those filament lamps Nelson was touching on metal objects, lighting them up.  You think it's magic?  No, it's volts times amps.  You just need to see where each part is coming from.  Volts you make, amps you get for free.  Just be real sure you only make volts.  If you make a Hertzian electromagnetic wave, Lenz will happily make you an opposing magnetic wave to wipe all your effort away.  All you want to do is put a coil of wire into motion, just electric motion.  Nature will do the rest.
Keep in mind this is all coming from me, a brain dead, ridiculous idiot.  Don't believe me, just ask MileHigh.  He'll gladly set you straight if that's where you want to go.
M@
Good Evening Dog-1
Believe you just hammered the proverbial nail on it's head........
This looks like the correlation between Nelson's post regarding the *extra* _ third coil.
Quote from: nelsonrochaa on April 14, 2016, 03:46:13 PM
Void ,
myself many times have some difficulties to linking and apply in practical my ideias;)  Is normal in research Work  because some of this informations are most of time "underlines" .
The most important sometimes is try to not let hour brain polluted because are so many information and different opinions about  this type of subjects .
about the post of Grumage with my old video is really a scissors  make contact with ground but in end of video in last minutes i show without ground , but that prototype are to old (8 months) but i  have that box yet in my home in Portugal, like other smaller basic circuits that i make  to record myself  that great things are made with first small results. :).
I think the important at present is understand how to replicate the extra coil circuit first and to that Lost Bro start sharing a good information .
If we have a big problem , better don't try to solve that in one shot ; better divide the big problem in small parts and it will more easy the journey  until end :)
good luck
Tesla's *extra* coil is only galvanically connected by a single wire, ie: Not inductively (k=0), so it will vibrate freely without said magnetic interaction with the Primary/Secondary which drive it (extra coil).
take care, peace
lost_bro
verpies
In the classical electromagnetic model that circuit is closed by pF stray capacitance.  That's why it does not work with HV DC and pulses are necessary.
Hoppy
Quote from: verpies on April 24, 2016, 04:16:16 AM
It should also be borne in mind that the energy source from the bench supply is supplying real current to the PWM generator, which is also closed loop and in turn is pulsing the bifilar coil.
Remember that Nelson said that there is a power supply needed to run the oscillator, so until we know the nature of that supply, we are unable to work out if his device is truly running overunity.
Zeitmaschine
I think it was a LED lamp like this.
So the Tesla coil radiates energy into space and part of this energy then is captured by the LED lamp. Can't see any magic here.
When I tune my radio to a radio station then does that radio station consume more power because I tuned in to it?
AlienGrey
There is a Don Smith video where he has a large plate of aluminium, perspex, then another aluminium plate where he demonstrates that experiments but misses out the importance of the experiment, the second plate is getting charge from the environment but does not show current draw on the primary side.
