0 Members and 778 Guests are viewing this topic.
Dog-One
Quote from: verpies on April 24, 2016, 04:16:16 AM
In the classical electromagnetic model that circuit is closed by pF stray capacitance.  That's why it does not work with HV DC and pulses are necessary.
When we have a signal in the 25kHz range I would think picofarads would be negligible capacitance.
What I find curious is the waveform.  Take an AC sine wave and rectify it with a full wave bridge rectifier--we get those lazy humps.  Now invert this potential and we see spikes.
Could this be important?
I'll bet the side you connect the earth ground to matters considerably.
Terbo
Quote from: Dog-One on April 23, 2016, 07:04:09 PM
Watch this video carefully:
https://www.youtube.com/watch?v=tDh7Uw5XC_w
That is 1600 volt peaks, rectified unipolar pulses.  Single wire, no closed loops, therefore amperage is flat zero, no electron flow and no magnetic field, purely electric agitation of the Aether.
@Dog-One
In your referenced video, Nelson Rocha[/size] claims he in sending unipolar HV pulses through a single wire system and harvesting radiant energy at the output of a full-wave bridge rectifier.  Take a closer look.  At 2:00 into the video, he connects the ground lead of his oscilloscope to the negative lead of the rectifier module on the output.  This closes the path from the power supply through the scope probe ground.  I have attached a schematic of the equivalent circuit showing this.  No magic here.
That which does not kill us makes us stronger - Nietzsche
Hoppy
Quote from: NickZ on April 24, 2016, 10:04:08 AM
  Main thing is to not use grid grounded devices, for these test. And only batteries, and real Earth ground connections. While at the same time turning the breakers OFF, to assure of having no ground loops, also.
Yes Nick and its been said many times! Otherwise we can end up with the situation shown by Terbo.
nelsonrochaa
Quote from: Terbo on April 24, 2016, 12:50:17 PM
@Dog-One
Hi Terbo ,
Well you are right about what you say, but in minute 5:29 are the ground probe  connected  ?..... the scope probe are connected directly in output without the bridge and without ground of probe  and what you see in scope ? ohhhh seems you don't see all the video ....
nelsonrochaa
Quote from: a.king21 on April 23, 2016, 05:12:19 PM
Nelson: in some of your videos you are using an imhotep relay to produce radiant energy. In your latest device are you completely solid state?
Hi King21
Yes i already managed to make completely solide state months ago . That videos with relay were very productive until a managed a way to deal without them . But is a good way to make experiments without the frustration of burn several components like usual happens .
And is not a imhotep relay actually i use two relays  ; will you understand why ... ;)
