0 Members and 600 Guests are viewing this topic.
verpies
Quote from: Void on April 26, 2016, 12:59:54 PM
I have also pointed out that the scalar part of the term apparently refers to the source of the wave rather than as indicator of a property
of the wave.
That's an important distinction.
BTW: According to the definition, scalar sources should be spherical in shape.
Scalar wave may be a bad choice to use for the name of this type of wave, but it seems to have come into at least some usage already, so it will probably be hard to make that term go away now... ;D
It is, but if one remebers what "scalar" or "pseudoscalar" really means, then rigor can be maintained and esoterics avoided.
Void
Quote from: nelsonrochaa on April 26, 2016, 12:35:46 PM
Void,
That box is not only wood , inside have plates of zinc in all box , and after have another layer that have the mesh shield that i already provide in link the manufacturer information .  and don't have any wire connection are only sit down in a table .
What i could say ... the input used in circuit  are half of watt , so is supposed be a high "EM"  ? No because with a gauss meter i able to see that is not strong .
I disagree  with talk you say:
without no corona discharge around a HV coil or wire, then there will probably be little to no radiant energy emission from that coil. What i tell you is based in measurements with a Geiger counter that could show the presence of high amounts of radiations like that you indicate .
I able to measure 245 u/sivert  with is more than substantial to reflect a bit .
Is important retain that are much to understand about some subjects , and without some workbench , read, and  and the right tools is more difficulty to form a opinion about subjects that normal are not discussed in the common lines .
Thanks
Hi Nelson. I don't know a whole lot about geiger counters, but see Grum's comment about how
geiger counters can be susceptible to giving false readings from nearby EM radiation. That certainly
seems to be a real possibility to me. By the way, a circuit powered by just half a watt can emit strong
EM radiations (depending on the circuit setup) in relative close proximity to the circuit.
Nelson, consider this. If you apply high voltages to a coil, etc, it is likely that there is still ionization occurring around
the HV coil or wire, etc.  that is not visible to the eye since it is at a lower level than in full out larger corona discharge,
but such ionization and subsequent recombination is probably still emitting some radiant energy/photons.
You have probably already seen this, but here is a video from Akula showing measured alpha, beta and gamma
radiations coming from a sparkgap. His readings on the geiger counter might possibly be skewed to some extent
by other strong lower frequency EM radiations coming from the nearby flyback transformer as well. I think Akula included in
another video that he has posted showing that the radiations coming from just a coil without a sparkgap are very low,
but off hand I can't recall which video that was now. I would have to search for it to see if I can find it.
https://www.youtube.com/watch?v=N0OAAAZaJ7w
Grumage
Dear Nelson.
Hmmm.... Yes my Geiger Muller is almost as antique as me !!   :)
Great to read that the latest generation are less susceptible to HF interference.
Cheers Grum.
verpies
Quote from: nelsonrochaa on April 26, 2016, 01:07:23 PM
Grumage,
Your are talk about radiation detected in radioactivity materials :) by radiation decay  , but you need to search a bit about artificial radioactivity created by ionization by particle acceleration ...
@Grum
That would be cyclotron or synchrotron radiation which ranges from RF to Visible to X-rays and Gamma.
Synchrotrons cannot generate Alpha nor Neutron radiation.
nelsonrochaa
Quote from: Void on April 26, 2016, 01:13:03 PM
Void i will not argue about that theme with you even because we are only share points of view , but you consider more than one meter enough  to prevent that  bad lecture? And health effects ? This could be real probe ... Its ok  just have careful dont say that  someone not talk about that .
You could find several studies related with that just search and you will find .
About how strong could be the Electro Magnetic field you did answer in best way .  Are you able or not to measure with a convenient tool the how strong could be a field ?
About the shield you even answer about last post .
I would sincerely ear your opinion face you experience with shield systems.
Thanks
