0 Members and 53 Guests are viewing this topic.
verpies
Quote from: d3x0r on April 29, 2016, 01:13:02 AM
also someone was making alternate dimension for everything basing all units in basic space-time units (m, s)
That would be this guy.
such as E=IR and R is  1/t.... but come to think of it his units didn't work... maybe it is T-1 ?
It works out just fine:
Resistance is T2S-3
Voltage is T1S-2
Current is S1T-1
verpies
Quote from: lost_bro on April 28, 2016, 03:13:43 PM
Has anyone ever tried a SiC diode (as D2) in a DSRD setup just for shits & grins?
Maybe something new to try ;D
There was a scientist that made his own SiC diodes for that purpose.  His paper is available for free somewhere on the net.
As a reminder - DSR diodes must be PN diodes with diffuse junctions*, long carrier life times and long reverse conduction times.  For DSR operation, it does not matter if they have low capacitance and recover quickly from reverse blocking condition to forward conduction (trr).
DSR diodes cannot be Schottky diodes nor PIN diodes !!!   ...regardless whether they are made out of Si, SiC, GaAs or what not.
The inductive spike is the desired output of the nanopulser which occurs when the DSR diode stops conducting very high reverse current in an inductive circuit.  Suppressing the output would be counterproductive.
*Spherical PN junctions provide the fastest reverse current fall times, because the moving carrier depletion front has a spherical shape.  These stored long-life carriers are the reason why the diode conducts in reverse.  For the DSR operation we want these carriers to be exhausted abruptly across the entire surface of the junction. Unfortunately most contemporary diode junctions are planar and sharp (no diffuse PN gradient).   "Poorly" manufactured diodes, such as the old Russian rectifying diodes, had overetched-in non-sharp (diffuse) PN junctions and that's why they work better as DSR diodes today.
AlienGrey
Quote from: MenofFather on April 29, 2016, 01:01:39 AM
Yes, here corect translation. End is shorted. Dally also mentioning in video, that end of coaxial is shorted.
Ha Ha!
Is this it ?
NO TITLE
Monday, September 10, 2012 2:11 + to quote pad
Well, there was at least some clearance in this dark realm)). After numerous experiments, we managed to get a very good result. I always thought the main criterion for a successful operation without fuel generator is samozapitka. Yes, yes it is, it puts everything in its place! So I managed to get recycling of voltage and current, or rather to get the system fills, and even take a little surpluses. At first I wanted to write that this device has Kapanadze replication, but I do not know him genratora devices and so on this occasion did not say anything mogu.Hotya course is mechanical installation T.Kapanadze inspired me to work in this direction. I saw genrator SR but also can not say anything on it, I have not used ferrites, or rather they are but the main coil does not contain iron, they are only used in converters.
In my installation I do not use a spark or arc, in all their manifestations. Well now on, that is for installation: In installing two generators, one generator shakes the converter on a ferrite transformer for nanosecond pulse generator power and respectively supply the voltage to the coil, then coil: includes klastikovogo frame and comprises 3 windings, one winding - wire approximately 0.25 to 0.3 mm (just make out where I can only say it with precise measurements, once shook mini Tesla, then it is overgrown with additional windings in the experiments). Then on top of it winding wire 0,65mm (call it resonance, it is connected only to 1,5mkf x 400V capacitors). Further winding coax 50th (previously used in computer networks) obtained bifilyar - end shorted winding - loaded to the generator of nanosecond pulses. And on top of wound coil pickup. The coil pickup loaded on a diode bridge, after the diode bridge are capacitors (not necessarily polar polar! do not stand up and sewn or inflated for a few seconds!) after I loaded rectifier lamp 20 W, respectively, and of the power supply for samozapitki. But still, I have gained the power supply is only one of the four, the old aT. One did not work at all, the two quickly went out of order. The diode bridge between the condenser and the coil is required! Without it, there is no stability work! If someone would teach me circuitry - I know that the power supply is a diode bridge, but it works much better. In genratoru nanosecond pulses - I crossed two generators for a reason - not found tunnelgogo diode. The circuit is taken from here:
Void
Thanks for the confirmation Menof. What does 'самозапитка' mean? Google Translate
does not recognize this word.
... Ah OK, I think I figured it out. it seems it means 'self-running'.  :)
MenofFather
Quote from: Void on April 29, 2016, 10:14:21 AM
Yes, selfrunning.
