0 Members and 850 Guests are viewing this topic.
Void
Quote from: itsu on April 30, 2016, 05:18:39 PM
The pulser did not like the open ended coax, it blew the IGBT (all 3 leads shorted) and toke the 250V driver circuit (ir2153 and 2x irf540) with it.
A new IGBT is in, as an ir2153.    Tomorrow i will replace the both irf540's.
This reminded me to my initial plan to insert a fast fuse in the 250V supply line  ::)
Itsu
Hi Itsu. Crikey, that was a bad break.
Maybe you can try driving the coax with whatever termination on its end that you are planning to test
with directly with your signal generator first, and monitor the signal generator output voltage
at the input to the coax to see how much it is loading down the output of the signal generator.
If it is loading down the signal generator output a lot, then that may be a configuration to avoid using
with the pulser. A 50 ohm resistor on any length of 50 ohm coax should like like 50 ohms resistive load at the
input to the coax, but the open circuit and short circuit at the end of the coax are transformed into a
different impedance depending on the length of coax and frequency you are testing at. Doing the signal
generator test should give you some indication of what kind of load the pulser will see if it were connected
instead of the signal generator directly. Just an idea... I wonder if the input to your coax winding with the open
circuit end looks like a very low impedance at its input at that length and frequency, or if the problem was that it
is a very reactive impedance which maybe your pulser did not like.... You should be able to get some idea about that by
trying the signal generator test, if you are interested in trying it.
Void
Hi Itsu. Actually, come to think about it, I guess at about 15 kHz a coax length of
only 8 meters is probably not going to do much of an impedance transform. :)
itsu
Quote from: verpies on April 30, 2016, 05:25:42 PM
I told you so  :'(
A bidirectional TVS diode that clamps the collector to emitter closely to the IGBT's maximum rated voltage, might have prevented this disaster.
Also, this is a lesson that D1 should have higher maximum ratings.
Finally, if I were you, I'd put the fuse in series with L1.
We are back in business, parts are replaced, and some tests done.
I have changed the 1n4148 (at the gate of the IGBT) for a Bat46 and added a fuse in series with L1
The D1 diode (600V same as the IGBT) did survive.
I omitted the "coax open end" test to avoid further damage for now.
I did do the "50 Ohm termination at the end of the coax" test and redid the "shorted coax" test, see screenshots below.
When adding a 100 Ohm trimmer potmeter to the begin of the coax with the far end being shorted, it initially showed (collector voltage half way at 130V) the same
signal as the "shorted coax" signal (pot halfway) but when turning a few turns the peak suddenly doubled so i stopped.
The potmeter measured to be in hundreds of KOhms now, so probably was fried, basically presenting an open (or high ohm) load.
Guess i need a somewhat sturdier potmeter instead of the trimmer pot used now.
Void,  thanks for your insights, but yes, the 8 meter coax at 15KHz will not present much of an impedance transformation.
Regards Itsu
itsu
Updated diagram,
changed D3 from 1n4148 to Bat46
added D4 (18V tvs).
added F1 (5A fast fuse)
added dots to T1
Itsu
Void
