0 Members and 675 Guests are viewing this topic.
verpies
Quote from: itsu on May 02, 2016, 05:12:07 PM
I scoped across the wima caps while in resonance (15.8KHz) to see what impact the nano pulse (1.5KV @ 12ns) would have on that signal.
The screenshot says it all, not very much!
Reversing the pulse on the coax (so pulse on outer shield) did not change that.
But the nanopulse can be seen over the 268VP-P sinewave, which is weird by itself since the shorted coax forms a self-cancelling bifilar winding.  It is the worst kind of winding for transferring energy to another winding by transformer's induction.
IMO the nanopulse is not supposed to have an effect on this sinewave.  Rather the sinewave and the nanopulse are supposed to have an effect on something else.
itsu
Quote from: Dog-One on May 02, 2016, 09:02:09 PM
Darn, that's a bit depressing.  I was really hoping your much improved test fixture (over Dally's) would show us the way.
So we're not back all the way to square one, but we are certainly missing something.  Any ideas as to what?
Don't be depressed or dissapointed guys, this was just a first test, lots of testing can/need to be done.
I measured the sine wave across the capacitor, not across the inductor itself (need to change the ground then), but will do that.
Also i could measure across the grenade output to see if that shows more of an disturbment.
I can also move the coax coil along the grenade/inductor, it now spans both, but it could try the inductor only, etc.
I count on you guys to continue testing with the kacher setup.
itsu
itsu
Quote from: verpies on May 03, 2016, 05:18:02 AM
This is not what I expected to see.  Most likely the probe position is wrong.
I allready thought you did not expected this, i will retest with the probe on the other side of the resistor, so between coax and resistor.
Itsu
itsu
Quote from: verpies on May 03, 2016, 06:04:09 AM
How did you synch it?
Is the phase shift between the sinewave and the nanopulse, smoothly adjustable between 0º and 90º in your circuit ?
I also connected the output of the TL494, which drives the push pull, via a switch (to select either TL494 output) to the input of the blue box which drives the nano-pulser IXDI414pi / IGBT.
The outputs of the TL494 is 15V, so i used a 1:3 voltage divider to input 5V into this blue box, see diagram below.
The blue box circuit can shift the input smoothly more then ±90° and also adjust the pulse width between 500 to 80ns (presently set to about 120ns for optimum nano-pulse amplitude).
Itsu
itsu
Quote from: verpies on May 03, 2016, 06:09:19 AM
Right, so hopefully that would be the grenade where the magic should happen, i will measure the output there.
An attached 40W did not show any change, but it could be to subtle to be seen.
Itsu
