0 Members and 170 Guests are viewing this topic.
DA1
Quote from: itsu on May 03, 2016, 07:43:17 AM
I also connected the output of the TL494, which drives the push pull, via a switch (to select either TL494 output) to the input of the blue box which drives the nano-pulser IXDI414pi / IGBT.
The outputs of the TL494 is 15V, so i used a 1:3 voltage divider to input 5V into this blue box, see diagram below.
The blue box circuit can shift the input smoothly more then ±90° and also adjust the pulse width between 500 to 80ns (presently set to about 120ns for optimum nano-pulse amplitude).
Itsu
Thanks Itsu  for information
ขอบคุณ Itsu  สำหรับข้อมูล
da1
T-1000
Quote from: verpies on May 03, 2016, 06:04:09 AM
How did you synch it?
Is the phase shift between the sinewave and the nanopulse, smoothly adjustable between 0º and 90º in your circuit ?
On the last weekend tuning session I realized about relationships between series resonance and the output. It lower output from grenade which is also connected to the yoke as soon as series resonance is locked with PLL.
After few hours with changing coils connections and frustration I made call to akula and asked how he was tuning his version of device. It turned out he is using 28-30T yoke winding to power Tesla coil and the grenade coil output is going directly to the load. Also he is trying to get standing wave with reflection from the ground under end of grenade and the resonant harmonic frequencies are in range with electrons movement Larmor frequencies. Which makes electrons push for the gain in the output.
So here is general tuning direction... :)
Cheers!
itsu
Thanks T,
so that would be something like Alexee has drawn, only difference here is that the ground is NOT connected to the "under end of grenade"
(meaning from the 6th layer through the middle of the former), but connected to the 1st layer.
Itsu
T-1000
Quote from: itsu on May 03, 2016, 10:43:09 AM
Thanks T,
Itsu
There are many circuits reverse engineering attempts. What Ruslan and akula did with grenade coil connections seems are different if there are no hidden truth about Ruslan case. In the end what akula is saying privately is more comparable with Dally circuit and makes more sense when doing series resonance on inductor. The grenade coil is like Tesla coil just making more current than voltage due opposite winding on L3-L6 to L1-L2. So the top winding goes to the ground and the winding under inductor become "hot" end and this is where top load from the Tesla coil is on.
And the yoke becomes "mediator" in akula case which is same as in Dally circuit.
Dog-One
Quote from: verpies on May 03, 2016, 06:09:19 AM
But the nanopulse can be seen over the 268VP-P sinewave, which is weird by itself since the shorted coax forms a self-cancelling bifilar winding.  It is the worst kind of winding for transferring energy to another winding by transformer's induction.
My thought on this is we are attempting to recreate the infamous "coil short at peak" scenario,
but doing it in a non-direct manner, using induction.  Induction has three forms:  Magnetic,
Electric and a combination of both.
If we think about the wave traversing the coax, it's clear there is a voltage potential spanning
just a few centimeters, that moves from one end of the coax through the length of the coax at
approximately 2/3rds the speed of light.  We have to visualize this is physical terms--a high
potential on the inner conductor, surrounded by a low potential on the outer conductor, where
the outer conductor is in close proximity to the grenade coil windings.  By means of electrostatic
induction with insulation on the outer coax conductor, insulation on the inductor winding and
more insulation around the grenade coil inductor, we must be influencing the grenade coil.
My feeling is we just are not doing this in a carefully physically controlled way so the pulse
range (in centimeters) maps accurately from one surface to the other.  Rather, it is being
mapped in a somewhat chaotic fashion, where the chances of cancellation are exceedingly high.
I'd like to be wrong about this, but having attempted to physically engineer the exact
dimensions of these coils, wire thickness, insulation thickness, overlap, circumferences,
layers, etc,  this can quickly become a daunting task.  It would take a mind like that of
Tesla to visualize where things will be at certain instances of time and align everything
up with great precision.  And with all that riding on the premise we know exactly what
needs to be done.
Makes me wonder of the couple of devices we have seen running, how many coils have
been wound by these same people that simply do not work.  I would bet dozens and
dozens of them.  I suspect "close enough" is actually a very lofty goal.  We could be
talking about precision in the millimeters necessary to get all the wavefronts to align
properly.
I wish I knew a way to simplify things down to the bare concepts we could test and
validate.  There must be some engineering tricks that can be deployed to allow us to
keep the critical physical aspects accurate and repeatable.
M@
