0 Members and 894 Guests are viewing this topic.
verpies
Quote from: Dog-One on May 03, 2016, 01:23:01 PM
If we think about the wave traversing the coax, it's clear there is a voltage potential spanning
just a few centimeters, that moves from one end of the coax through the length of the coax at
approximately 2/3rds the speed of light.
Yes, like this but one pulse only
verpies
My feeling is we just are not doing this in a carefully physically controlled way so the pulse
range (in centimeters) maps accurately from one surface to the other.  Rather, it is being
mapped in a somewhat chaotic fashion, where the chances of cancellation are exceedingly high.
I thought along these lines at the beginning of this thread. See here.
GeoFusion
Hi Guyz :)
Itsu,
thanks man :), yeah the circuit is amazing, the effect is beauty, yet this is just one way to skin the cat,
the Ruslan way is Real :).
   For all.
Btw I have tried it without PSU, so using 12V battery input and the effect is still there and ground is still working :).
   Itsu.
yes, Akula's way is real as it is, Mediator is The  Yoke :), as T-1000 has said.
As same as the Toroid which is drivin by Dally's TL494 circuit,
is the " mediator of synchronization ". I see Dally's could be one very easy one to replicate and try out
as same as he has it on his diagram. I think You can do it Itsu :).
You have the Coax already , now it's to see how synch. will happen :). That toroid is very important!
Nicee, PLL drivin by TL494  ;D lets see how that one works out.
Oh yes, that Schematic of Alexee Sergey needs to be tested, I see it will work, Yoke is Mediator :).
will need fine tuning thought. Same as how Akula has it.
Video of Alexee Sergey Showing Scope and When connecting load at the same time and showing
circuit
https://www.youtube.com/watch?v=4XPA__Kfets
Void,
Yes, safety is something serious at these times ;),
yes, being bear foot is not a option, for what I know now
I have to be protected by all cost, this output is nasty stuff but brilliant.
Well what I could say is, I saw OU for sure, what I have seen couple of days ago but it's
how you tune it and having necessary parts connected as how it should :).
But what Made my day and buddies is, It drives the same when connecting
batteries, Same effect and ground differences. :) Mains has no influence on circuit
while working with PSU.
   Cheerz~
Void
Quote from: T-1000 on May 03, 2016, 10:27:37 AM
After few hours with changing coils connections and frustration I made call to akula and asked how he was tuning his version of device. It turned out he is using 28-30T yoke winding to power Tesla coil and the grenade coil output is going directly to the load. Also he is trying to get standing wave with reflection from the ground under end of grenade and the resonant harmonic frequencies are in range with electrons movement Larmor frequencies. Which makes electrons push for the gain in the output.
So here is general tuning direction... :)
Cheers!
Hi T-1000. Thanks for posting more info from Akula.
It is not clear to me however what Akula actually stated and what you
may have added onto that in your statement above. Did Akula specifically say that he thought
it was NMR or similar that was causing the OU effect, or what exactly did he say? If Akula stated he thinks
it is an NMR effect causing the OU in this type of setup, when Akula is referring to this NMR or NMR-like effect,
does he think this effect is occurring in the copper wire in the grenade coil itself, or in the ferrite in the yoke
core, or in the copper windings on the yoke core, or where exactly dies he think this effect is occurring?
Also, have you asked Akula if he thinks Ruslan's various supposed self running device video demos are real or fake?
It might be helpful to know what Akula thinks about Ruslan's videos.
verpies
Quote from: Void on May 03, 2016, 03:10:13 PM
does he think this effect is occurring in the copper wire in the grenade coil itself, or in the ferrite in the yoke core, or in the copper windings on the yoke core, or...
...or in other purposely concealed gain medium.
