0 Members and 1510 Guests are viewing this topic.
itsu
Hi apecore,
great initiative, but as T-1000 already mentioned, there is a lot of confusion and misunderstanding going on because nobody really knows
what the correct MO (modus operandi), diagram, tuning sequence, etc. is.
So putting some highlights, crucial results and working methods in your document is fine, but we only know if it is of value if it produces the wanted effects.
Further more, most of us are doing this out of interest or motivation, but often that interest shifts to other projects leaving this thread dormant for weeks / months
Hopefully your  QA (quality assurance) management skills are able to put some order into this chaos, i will try to contribute as before as presently i am motivated to
get this nano-pulse hybrid going.
Itsu
itsu
I made these changes and observations:
# rewound the grenade layers 3,4 and 5,6 to be of opposite direction of layers 1,2 (again).
# Disconnected the 28 turn yoke secondary from the grenade (left it open)
# connected the 6th layer return wire of the grenade to ground.
The results are similar as earlier reported.
Shifting the coax cable coil away from the inductor/grenade has i big influence on the output of both the inductor and grenade.
Probably the Q of the inductor suffers greatly from this tightly coupled coax coil.
I will rewind the inductor / grenade so that the coax coil is between the exposed layers 1,2 of the grenade and the inductor leaving the Q of the inductor
unchanged hopefully.
Another change is the adding of this free running parallel LC coil, which should be first on the former (i think) and needs a parallel resonance frequency
of 15.8KHz (i think), same as the inductor series LC resonance via the push-pull driver.
Itsu
starcruiser
@ITSU,
I think this was a coil wound with the same wire as a Tesla coil secondary (I seem to remember that) 26 awg or so, I would think the resonant point would be in the 1.5 to 1.8Mhz area, a harmonic of the 15Khz LC tank. In any case the wire gauge would need to be smaller since the 12 or 14 awg wire for the grenade is very long and folded back on itself a few times, I would think you would want a single layer correct? Potentially spanning the entire length of the grenade 12 or 14gauge coil.
Regards,
Carl
itsu
Hi Starcruiser,
yes, a 300 turn or so single layer Tesla secondary like coil.
I have one which selfresonates (in a kacher setup) at 1MHz, but i just tested it with a 47nF capacitor parallel, then this LC resonates at 12.8Khz.
So i will use a similar coil underneath the grenade spanning the whole length and set the resonance to the same 15.8KHz (or so) my pushpull is putting out
to excite the series LC inductor/wima caps.
Itsu
Tomtech29
Hi.
I think that you are interested.This test system using both the coils in the opposite direction
I am of the opinion that as described Itsu : "Does that mean that according to Akula the Grenade should be (like it was) layers 1, 2 CW, layers 3, 4 and 5, 6 CCW"
Yes.
I heard that the layer 1, 2 CW above  It contains a clamp aluminum foil (open circuit end)
-interesting is that the system tank circuit "LC"  the determination of harmonic It does not affect the resonance behavior does not  changes when we turn on the load!
I thought that this is a very important issue And at least for me. Something for a long time I could not understand why is it that he has this "state of resonance"?
I recommend to see :
https://www.youtube.com/watch?v=UX9tn2NxWuQ
8:27
Itsu
you are predisposed to get closer to this effect obtaining answers to this ill (I follow your charts the course and the interaction effect of pulses on the coil)
-fills this new optimism :D
very cool I think you guys can see it how are you try and appreciate it.
Also considering this option that the circuit 28T. the yoke It could be used only to power the Tesla coil as it was in the case of "Akula" for this reason
not saying that this second example is wrong
I have this big handicap the resistance of the circuit 28 winding It has a sizable advantage on power consumption from the power supply
(power curve) you would have to figure it out...
inductor creates a magnetic flux but if he had variable directions on the oscilloscope it looks like a flowing "fish" you've seen it on the installment Ruslan (as modulation AM)
it seems to me as if two frequencies they overlap?
yet there is no end something is smoldering :P
I greet you with warmth.
