0 Members and 218 Guests are viewing this topic.
N20Wolf
Hello Everybody! I spread the oscillator circuit, by Sergey Alekseev.  Download Torrent File - "БТГ - Бестопливные Генераторы, от Сергея Алексеева.rar.EX.UA". All information in the archive!
Download Link, on Torrent: https://yadi.sk/d/008VwSe4rAGQk
NickZ
  There may not be a specific magic frequency, as each self runner is running at different frequencies. And can still suppose ably self run, (if true).  But, there does seam to be an certain relation of frequencies for each circuit or device, to be a proper sync, with gain.
   I can't even get my Kacher working, still won't oscillate as it should. Now with new 2SC5200 transistors, barely lighting a CFL bulb, while getting too hot in one minute running. I changed every component a few times, and, I even rewound my Kacher secondary coil, thinking that it might be the problem. But, no change still.
   Jeg: Did you get your Kacher working right yet.  IF so, what was the problem when it won't oscillate?
  The Kacher driver is such a simple circuit,  but, it can be a real pain in the ass.  I hate it when that happens.
Jeg
Quote from: NickZ on May 08, 2016, 04:56:07 PM
Hi Nick
If you barely light a cfl bulb then your Katcher works. I mean don't wait more things with 24V power supply. Yes it gets hot. It is normal. But even with this small voltage we have seen a Ruslan's device working. Anyway. Still learning ;)
GeoFusion
Hi Guyz :)
Hope all is well.
For all, I have some videos I would Like to share,
Geofusion Effect 4 with Diode Bridge test with load
https://www.youtube.com/watch?v=OCBsSUmndcI
Geofusion The Original way, Akula way. !
https://www.youtube.com/watch?v=tKPm89wB-s0
Two videos here will show many differences, yet they work!
I could say now Ruslan and Akula (Roman ) Devices are real.
Just ppl need to replicate them right :). Good guidance is needed.
For the idea, I got 175V output at grenade, Bulbs are super hot, you feel heat radiation coming form them.
Thoughts on Roman way, Fine tuning is strongly required to get maximum here in comparison with Ruslan way.
Ofcourse AlexeeSergey's replication also reall thing there. :)
Itsu,
Nicee ;D saw your recordings and photo's of the new grenade with telsa windings on it , coax and inductor afterwards.
hope it works out :),
What I would like to see when you are stest driving these circuits is to hook them up to the mediator core
(Toroid which provides input for both circuits ) to see effect happen! :) you can do it.
I have some vid for you here, take a look at it
It is important and can help you to see what needs to be achieved in signals
there are scope shots in this video.
https://www.youtube.com/watch?v=Sa30TbM6wak&feature=youtu.be
Same AM modulated signal you will see here and how he synch both signals.
This is where things start to happen :). take a good look.
This is also good one of Ruslan when he was still busy on the Dally Device,
Look at the mediator core inside the box, there is usefullness in this one
https://www.youtube.com/watch?v=m0ztyPxXcas
Nick,
you are  right, all system will vary on freq with modulations.
About Kacher Nick, Did you use my Diagram i posted befor? It has Kacher on it.
I think If it overheats instantly there is short somewhere...
Take a better look at the circuit, coiling should not be the problem and at first try to make a long Secondary at first.
try to make kacher without Beginning inductor which is provided in diagram
and without the 2 Diodes also. Let me know ;)
Cheerz~
beboszek
Quote from: NickZ on May 08, 2016, 04:56:07 PM[/font][/size]I can't even get my Kacher working, still won't oscillate as it should. [/size]
[/font][/size]
Nick, if you want to explore setup with blocking oscillator, called "katcher" by all of you, then you can use circuit I'm attaching below in pdf. You need to achieve oscillograms like on the picture. When properly tuned, radiator is just warm.
