0 Members and 44 Guests are viewing this topic.
magpwr
Quote from: beboszek on May 09, 2016, 04:16:22 AM
[/size]
Nick, if you want to explore setup with blocking oscillator, called "katcher" by all of you, then you can use circuit I'm attaching below in pdf. You need to achieve oscillograms like on the picture. When properly tuned, radiator is just warm.
hi beboszek,
Congrats you are one of the rare few in here whom is able to self fabricate a pcb not forgetting designing a circuit as well.
Why not create a "Parametric Oscillator" base on one of Akula circuit using op-amp(TLC272) ->inverter,4017,pulse shaper using dual inverter to get duty to 50% then feed to IR2184.And yes base on Royer setup.
I have just Reserve Engineered Proof my design to 3 i/c using Microchip PIC but i am planning to reduce to 2i/c without nanosecond circuit.
So if you connect a eg:60watt bulb to output the input at 24volts should drop without activating nanosecond circuit.
Lastly it make sense why bulb is always turn on last base on the above design.This is super important.
The input current for my case is mere 0.23Amps at 24volts with bulb connected at output and 0.28Amps without bulb.
If you try Half tesla and around 1/2 high Q coil then you can see voltage + current movement to Earth not at innocent voltage at 24volts but higher.
My tesla is running at 22KVpp at mere 28watt..30watt using SIC with snubber with nanosecond interrupter.Then you can see spark at ferrite rod base on old Akula video.
I may or may not reveal the final product in my youtube channel "sanjev21"
But i am still confident 99% of you are lost like Jurassic Park.
I have mentioned previously i do have offline pc for designing but in this experiment everything is assembled without pc since it is still on breadboard for now.
So don't bother trying to be an Professional paid idiot hacking into my pc you will find nothing of importance.
;D ;D ;D
I already knew beforehand my pc don't stand a chance since even gov server were hacked base on news we see. :)
That's all for now.Don't expect me to response back.Radio out.
God bless America.Since i love what i see like to happen to suppress China.
NickZ
     Geo:
     You mentioned:
   "About Kacher Nick, Did you use my Diagram i posted befor? It has Kacher on it.
I think If it overheats instantly there is short somewhere...
Take a better look at the circuit, coiling should not be the problem and at first try to make a long Secondary at first.
try to make kacher without Beginning inductor which is provided in diagram
and without the 2 Diodes also."
   And, so, I did that... Yes, I followed that diagram, but, I found the problem to be the two face to face zener diodes, along with the 1.5k ohm resistor. Which are NOT right for my set up.
Once I removed the zeners and the 1.5k ohm resistor, the driver fired up like it should.
This was using a brand new horizontal deflection transistor.  But, I have two other small breadboard circuits partially built up, which have the 2sc5200 on them.  I'll get those up and running, now that I found what the (not oscillating) problem was
  So, Wrong component values on that schematic?  Or what?
  Geo, thanks for your help. Now the sparks are intense and RF burns hurt.  So, maybe I could use some more turns on the Kacher secondary, like you are using, also.
   I don't see the long (1 cm wide and white luminous) streamers on your latest videos.  Why is that?
   You shortened the Kacher's secondary coil?
AlienGrey
Quote from: AlienGrey on May 07, 2016, 03:40:24 PM
Tomtech 29 yes I have a layout for the original device that was published some time back but this one you have put up is a newer version How is it possible to send you the lay out ?
I have not tried running the device on a unit but all the signals are available on the unit, ;) but have I got to start again on version 3 ?
photo of layout below.
itsu
Quote from: GeoFusion on May 08, 2016, 06:00:07 PM
Hi Guyz :)
Hope all is well.
For all, I have some videos I would Like to share,
Geofusion Effect 4 with Diode Bridge test with load
https://www.youtube.com/watch?v=OCBsSUmndcI
Geofusion The Original way, Akula way. !
https://www.youtube.com/watch?v=tKPm89wB-s0
Two videos here will show many differences, yet they work!
I could say now Ruslan and Akula (Roman ) Devices are real.
Just ppl need to replicate them right :). Good guidance is needed.
For the idea, I got 175V output at grenade, Bulbs are super hot, you feel heat radiation coming form them.
Thoughts on Roman way, Fine tuning is strongly required to get maximum here in comparison with Ruslan way.
Ofcourse AlexeeSergey's replication also reall thing there. :)
Itsu,
Nicee ;D saw your recordings and photo's of the new grenade with telsa windings on it , coax and inductor afterwards.
hope it works out :),
What I would like to see when you are stest driving these circuits is to hook them up to the mediator core
(Toroid which provides input for both circuits ) to see effect happen! :) you can do it.
I have some vid for you here, take a look at it
It is important and can help you to see what needs to be achieved in signals
there are scope shots in this video.
https://www.youtube.com/watch?v=Sa30TbM6wak&feature=youtu.be
Same AM modulated signal you will see here and how he synch both signals.
This is where things start to happen :). take a good look.
This is also good one of Ruslan when he was still busy on the Dally Device,
Look at the mediator core inside the box, there is usefullness in this one
https://www.youtube.com/watch?v=m0ztyPxXcas
Nick,
you are  right, all system will vary on freq with modulations.
and without the 2 Diodes also. Let me know ;)
Cheerz~
Geo,
thanks for the links.
Not sure where to place the, what you call, mediator, which is a mixer as i understand it.
I only have the nano-pulser and the push-pull generator, both supplied from the same 24V battery stack, so there is not realy something to mix.
The nano-pulse repetition frequency is already synced with the push-pull generator.
Anyway, good to see your experiments seem to point you into the right direction.
Itsu
Tomtech29
Quote from: AlienGrey on May 09, 2016, 11:05:52 AM
You had a problem with a private news ?
with this form I do for nothing useful
- if  you can send me e mail or  try in Annex pack winrar
Thanks.
