0 Members and 330 Guests are viewing this topic.
Tomtech29
Quote from: beboszek on May 09, 2016, 04:16:22 AM
[/size]
Nick, if you want to explore setup with blocking oscillator, called "katcher" by all of you, then you can use circuit I'm attaching below in pdf. You need to achieve oscillograms like on the picture. When properly tuned, radiator is just warm.
I left for you Pm as you will want to talk thanks.
Welcome to all of us.
Jon_sparky
You may have some ideas to do something with this what has to be a unique chance to bring new energy finally out into open public domain?
Dr. Steven Greer - "Call for New Witnesses": UFO, Secrecy, Cover Up, Free Energy +
https://www.youtube.com/watch?v=4S6muRqc3Sc
Dr. Steven Greer Announces "The Campaign That Ends Illegal UFO & Free Energy Secrecy"
https://www.youtube.com/watch?v=GlPPzU-rqp4
Unacknowledged - An Expose of the Greatest Secret In Human History : From Dr. Steven
https://www.youtube.com/watch?v=0ZKlQrI8qNw
GeoFusion
Hi Guyz :)
    Nick,
Ah Nice :) so it was the Zeners and Resistor which did not alow it to work, Wierd but ok.
Well in the schematic that is exactly what i have installed on my kacher :-\.
Yes, watch out for Nasty RF plasma burns.
The long streamer only come out when putting 24V on , but when you see it less it is below that voltage.
Yes I have shorten it to the same length as the grenade, almost. But will get almost same results when having
it hooked up with antenna, the streamer increases length too and that is where it becomes  les purple but orange
with some white stream RF. It looks like it gained Amps :). that one if arced on skin will Instand Vaporize a hole.
   Itsu,
I have managed to get some Diargams for you where I have pointed out what you should try and
what the the mediator was sins the very beginning when the schematic was drawn.
See Below the 2 Diagrams
I picked out 2 diagrams and I think these are good to try out , I might draw another one but these 2 will do
as example.
See where the mediator is ( Toroid/Yoke )
Supplying the Nano Second Generator and Pushpull Generator Mosfets/ Transistors input.
it's only that toroid will supply it! not strait from battery supply. You will see the effect when doing this :)
Let a Simple TL494 Inverter drive the Toroid-Yoke as it would be a primary pushpull.
Source of PSU will only be fed to the circuits of Nano pulser and Pushpull driver IC circuitry nothing els.
After this you will see effect for sure without a doubt Itsu :).
Probeer maar, het gaat lukken! Een maal de sleutel gevonden, kunnen we zien wat gedaan moet worden!  ;D
Let me know
Cheerz~
itsu
Geo,
thanks for the diagrams, i had already seen them as my present setup is based on those.
Only difference is that the 150V DC of the nano-pulser is not coming from
the "mediator"  (which is the yoke), but via some other source.
I don't believe that there will be any difference when using the 150V dc created by the yoke (mediator) or by the
way i have done it, 150V dc is 150V dc (i have doubled that to 260V by the way).
But i appreciate your efforts,  thanks.
I think there is an item missing in those diagrams which is the extra stand-alone parallel LC circuit.
I think it must be underneath all other coils, like it was with Dally's initial setup.
Itsu
AlienGrey
Quote from: GeoFusion on May 09, 2016, 04:51:31 PM
Hi Guyz :) GEO and ITSU **********************
Let me know
Cheerz~
Let met get rid of quote and get to the nitty gritty point of Nano pulse and co-ax, yes it's all very confusing for me as co-ax length and short for me alters the standing wave I assume in this case from my telecommunication days and Prof Curtis, anyway so what frequency to select for standing wave and also the tuned grenade coil, so how you work that  out and whats the formula ?? ;) Geo your the man any ideas ? ;)
