0 Members and 295 Guests are viewing this topic.
T-1000
Quote from: itsu on May 09, 2016, 05:18:39 PM
Only difference is that the 150V DC of the nano-pulser is not coming from
the "mediator"  (which is the yoke), but via some other source.
Hi itsu,
The peak of 150VDC is on peak of the on series resonance current. This is same as in Dally original circuit. There is difference on that against direct power source.
And it seems is critical for sync of both voltage sources at least in Geo place.
Cheers!
NickZ
  beboszek:
  Thanks for the idea of using that type of Kacher circuit, however,  I'm working on trying to replicate the previously shown Ruslan type of Kacher circuit. Even if the transistor gets hot. As he had it working on his set up as a self runner, and it's simple to replicate. Or so I thought, until I tried to get it working right.
  Is what you are showing your device? What can it do?
   Thanks again for your suggestion.
                                                      NickZ
itsu
Quote from: T-1000 on May 09, 2016, 06:19:57 PM
Hi itsu,
Cheers!
There is no "peak of 150VDC", there is just the 150VDC created from the yoke (mediator) or from whatever other source like in my case.
The 150VDC is the input for the nano-pulser, like the steady anode voltage of a radio tube.
The input pulse to this nano-pulser is derived (so synced) from the TL494 PWM and adjustable (delayable), so therefor i can have this nano-pulse fired when i want.
Best results (flickering Grenade output bulb) is indeed when fired on top of inductor voltage at resonance or at zero-crossing of this inductor voltage at resoance
(which is the top of inductor current).
Itsu
AlienGrey
Itsu AND NICKZ
[/quote] the drive transistor will get hot if it is not fully turned on or off ! It's back to the old story ;) If you want the tesla driver to work properly make sure it's driver turns on and off and it's in resonance, Itsu you have all the kit to show all that at your disposal ! i wish you all the luck and guidance you can get !
Also some tesla coils have a split copper tube or alloy inner tube with a vortex coil in the center cw and ccw boost system, have you seen that ?
ag
Jeg
Quote from: AlienGrey on May 10, 2016, 04:39:14 AM
Great observation AG. Thanks ;)
Geo
Nice videos man. I saw 2-3A without katcher. What is your consumption when katcher is on?
