0 Members and 2079 Guests are viewing this topic.
itsu
Quote from: AlienGrey on May 10, 2016, 04:39:14 AM
Itsu AND NICKZ
the drive transistor will get hot if it is not fully turned on or off ! It's back to the old story ;) If you want the tesla driver to work properly make sure it's driver turns on and off and it's in resonance, Itsu you have all the kit to show all that at your disposal ! i wish you all the luck and guidance you can get !
Also some tesla coils have a split copper tube or alloy inner tube with a vortex coil in the center cw and ccw boost system, have you seen that ?
ag
Alien,
yes, i have seen that, in fact i did some testing with it years ago, see this video:
https://www.youtube.com/watch?v=WH2BI6bZsAg
It did not turn out to be anything special then.
Itsu
T-1000
Quote from: itsu on May 10, 2016, 04:06:15 AM
There is no "peak of 150VDC", there is just the 150VDC created from the yoke (mediator) or from whatever other source like in my case.
The 150VDC is the input for the nano-pulser, like the steady anode voltage of a radio tube.
The input pulse to this nano-pulser is derived (so synced) from the TL494 PWM and adjustable (delayable), so therefor i can have this nano-pulse fired when i want.
Best results (flickering Grenade output bulb) is indeed when fired on top of inductor voltage at resonance or at zero-crossing of this inductor voltage at resoance
(which is the top of inductor current).
Itsu
It is still worth to try and see if it makes any difference. You never know for sure otherwise. I would prefer following Dally schematics with own way of components making same function as it was in Ruslan case.
AlienGrey
Quote from: Jeg on May 08, 2016, 02:17:24 PM
Thanks kolbacict. It is just that I don't believe in magic frequencies in relation to Ruslan's and akula's devices.
your a case, look at circuit no 2 of Alexeew see picture and take note of this data on this picture ! ;)
try dividing it by 3000. Then try translating it into English !
1/.   zhvitkovaya folga aluminiy  ne zamknut ILI aluminiy truba s razrezom ne zamknut.
>>  Winding aluminum foil is not closed or aluminum tube with a slit is not closed.  <<
