0 Members and 53 Guests are viewing this topic.
Сергей В.
THEY RULE HERE !! WATCH VIDEO - CAN'T BE SEEN IN EYES SPECTRA WITHOUTH CAMERAS !! SO BUY CAMERAS - RECORD 24 HOURS/DAY AND YOU WILL KNOW WHAT AM TALKING ABOUT !!
http://www.youtube.com/watch?v=llnOm3BUV78
UFO BOOM IN CANADA MORE THAN 2000 eye-witness testimonies. Great number of Abducted and Implanted people - {VOID - zombie mode }!! Number rise quickly in all countries.
JEWISH WORLD GOVERNEMENT "UNITED NATIONS" KEEP MOUTH SHUT AND FINANCE INTERNATIONAL TERRORIST TO MAKE A WAR IN INDEPENDENT COUNTRY SYRIA.
"UNITED NATIONS - NEW ZION WITH CENTER IN NEW BABILON" - PROTECT THEIR EVIL ALIEN BOSSES !! MANKIND SLEEP !! DRONE KING OBAMA LAUCHED 1.2 BILLION PIXELS CAMERA DRONE SQUADS. 3000 DRONES OVER AND 2500 LIGHT TANKS ENGAGED.....
MAKE CONCLUSIONS !!
NickZ
  Thanks for the info CepreN B.
    As I don't have a scope to tune the circuit with, here is a good example of how to tune the toroid, yoke, or ferrite rod cores and their windings. The same procedure can be used on all the cores, by adding or removing winding even without having to cut the wire. I use a single light bulb, and a garden solar light photo resistor tapped to the bulb, and connected to my volt meters ohm setting, to gauge the bulb brightness, by the given resistance value.
  The ferrite rod in the video below is what I use to give the pulced Ac of about 1500 volts to my yoke, of 12 turns, opposite wound center tapped red wire. I also have another coil next to it on about 20 turns single later, open ended.  I then use a 3 turn thick output coil going out of the yoke, which goes to the cap, then to the big air coils resonant coil.
  I have not started to tune my circuit yet until I obtain my various capacitors, as I know it won't work the same without them.
  Grum: this set up below can also be used on your toroid core, until you find a yoke to use.
   LaserSaber video, fairly resent from April 19th 2013, about coil tuning.
   http://www.youtube.com/watch?v=vVXzGcyzu6o
Shokac
Uses this circuit.
This curcuit automatic resonance all staf in secundary windins.
@NickZ:
Great work! AT LAST somebody is actually measuring the light output with an objective instrumental method, instead of saying "Golly, look, a 100 Watt bulb is lit up, so there must be 100 Watts there! And this bulb is even brighter, so it must be putting out even more than 100 Watts!!"
Anyone who is using light bulbs or even LEDs for loads and looking at light output for an output power judgement _must_ develop some kind of instrumental means of measuring the light output, because subjective impressions are not reliable, and just because it says "100 Watts" on the label does not mean that the bulb, when glowing brightly, is actually dissipating 100 Watts or that all the power you are giving it is coming out in visible light.
@Shokac:
Congratulations! You've discovered the Royer ZVS Oscillator!!
http://www.youtube.com/watch?v=4XRwlNCF1PU
http://www.youtube.com/watch?v=9x2YfA9LU5s
http://www.youtube.com/watch?v=Lb1UpX0-Q00
@Sergei V.: LOL.....
Hoppy
Quote from: TinselKoala on May 18, 2013, 06:41:54 AM
@NickZ:
@Shokac:
Wow, some mean free energy in those demos. You clearly have the Kapanadze secret!  :) Watch out for MIB  ;)
