0 Members and 156 Guests are viewing this topic.
Dog-One
Quote from: T-1000 on May 23, 2016, 11:45:14 AM
Well, quite off-topic but I would like to add another case to this - http://laserhacker.com/?p=491
And all these experiments are directly related to residue magnetic field in the core which makes things to happen...
Please forgive us.
I do think two coils wound on top of each other is a basis for a capacitor.  How this is done and the materials used is a basis for the stability that can be achieved, if at all.  I stress this later part, since it appears, hit-n-miss with each of our replications.
There is discussion on other threads about what a magnetic field may do in proximity to a capacitor.  The patent DE20317795 describes a solenoid wound in what appears to be a coaxial cable using the inner insulation as a dielectric.  The claim is a much improved solenoid (possibly overunity).  The mechanism behind this invention looks to be the generation of a magnetic field using only charge, not electron flow.  I think everyone can see the utility in this concept--essentially, you can transfer power without in any way loading the primary power source.
I'm not clear how exactly Kapanadze, Dally, Ruslan, Akula and the like have achieved their successful devices, but there does seem to be a common thread in the mechanism--charge movement without (or with only partial) electron current flow.  These high voltage Tesla coils and nano-pulsers provide the charge, but the means to initiate movement must be timing and synchronization.  Geo stresses a mediator coil.  This may be one of several ways to achieve the same effect.  My feeling is the high voltage impulses (Tesla and nano-pulse) are also traversing the power rails in the case of charge movement.  Nelson has shown the ground connection to benefit the effect, but it is not required if the principal is understood.
All roads lead to Rome.  We just need to identify the clearest path to get there by piecing together all the available information.  I think simple experiments are the way each of us can learn this.  Nelson's RochaBoard (my term) is an interesting starting point, though I will stress it contains complexity beyond the circuit and components used.  Hidden in that device is the mechanism we must come to understand and capitalize on.  From there it is quite possible each of us can build a functioning device to our own liking; maybe even compare notes and improve upon them.  With some serious focus and dedication, we might even be able to show Ruslan a thing or two.
M@
Reiyuki
Quote from: Dog-One on May 24, 2016, 04:32:27 PM
That's a pretty neat patent you mentioned.  I'll have to bench-test that (probably requires HF/HV for real output though)
Link to patent DE20317795 with translation and pictures:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0ahUKEwi6y8es1_PMAhVX4mMKHXGBCZUQFggdMAA&url=http%3A%2F%2Fwww.overunity.com%2F11063%2Fsimulation-of-the-muller-dynamo%2Fdlattach%2Fattach%2F54455%2F&usg=AFQjCNFVDxfwyZnGJUv81sMXgd178rdRqg&sig2=SnTTUfeNaSLYXhlZOqdH-A
lost_bro
Quote from: Reiyuki on May 24, 2016, 05:51:15 PM
Reiyuki : Thanks for the Link and translation
@ Dog1: So it appears to be bi-filar wound and capacitively coupled (without galvanic coupling between bifilar windings)....... looks like a novel approach that could be applied to any number of experiments which utilize bifilar windings. ;D
take care, peace
lost_bro
T-1000
In regards to changing electric field and how it influence magnetic field you may read http://www.oberlin.edu/physics/dstyer/Electrodynamics/ChangeChange.pdf
In Kapanadze style devices the nanosecond high voltage pulse is going along these lines with high tension magnetic field from inductor.
You may also think from standpoint of how you can disrupt magnetic field on the coils without spending energy to make it move... And on top of this adding standing waves to attract positive and negative charges on grenade coil ends. Which is getting polarized according to akula explanation.
Cheers!
Jeg
@Verpies, D1
Hallo guys. I have attached a simple drawing presenting a primary and a secondary coil.
At secondary side when there is one diode like that, and when i am trying to scope the rectified signal attaching my probe at the output, the signal i get is not a rectified like signal as expected, but looks like a complete sinus above and below the zero line.!!! It is like my oscilloscope can not recognize the reference point in which i attach my probe's ground.
When i add one more diode (cathode at point A, anode at point B), the signal at my scope is presented rectified as expected. Why is that? I mean shouldn't my scope show a rectified signal even with one diode in the circuit?  :o
