0 Members and 665 Guests are viewing this topic.
AlienGrey
Quote from: NickZ on May 26, 2016, 09:10:48 AM
  Jeg:
   Today I'll complete the full bridge rectifier using those IN5408 diodes, for the Kacher's input source from the 28t coil. This 28t yoke secondary coil will NOT be connected to the grenade.  As I could not find resonance between the Kacher, and the induction circuit previously, with the 28t yoke coil connected to the grenade's 168t coil. And now my Kacher is stronger than it was before.
And, it looks like he stronger the Kacher's output, the brighter the bulbs, and "effect".
   Thanks for the reply.  And good luck with your project.
   TomTech:  With the induction circuit running, and NO load, I get was getting over 1000v output from the 28t coil. With or without the grenade connected. This was the normal output of my set up, when using the Mazilli as the driver, when it's running on a 12v, or 24v source.
Nick don't use 1N5408 diodes they are far too slow for this type of work get some FAST low break over voltage type. Like MUR460's
Use something like this http://www.onsemi.com/pub_link/Collateral/MUR420-D.PDF
NickZ
  AlienGrey:
  Yes, thanks,  I'll see what I can do, but for now the IN5408 diodes have already been installed. We'll see how they work out for this. I can always switch them out, if they don't do the job.
  I'll be getting stronger 4A diodes like the MUR420 (25ns) that you recommended, to build the full diode bridge, that will be mounted on a heat sink for the grenade's 168t output coil. They're also really inexpensive. But, they can't be mounted on a heat-sink, for added cooling, like the 220 package ones can.
  I'd like ask Itsu how his bridge diodes were working out, as far as heating up, or not. And which diodes he is using.
GeoFusion
Hi guyz :)
Nick,
Well there is alot of good news and alot still to test :).
hopefully to post a new vid for the eyes to see what is going on.
But I wanted to point out to not really use the smaller green toroid, just use the Yoke as mediator for the work.
The diameter of what the yoke ferrite is perfect.
The red windings ( secondary ) on mediator yoke should not be to thick. use thin wire about 1mm diameter.
reason why you also fried some of your circuitry. The voltage you see on 28T is not correct, it's the ions
that are making the false readings on meter, 28T will generate a amount when having power supply connected to
mazilli as how it should but the mix will happen eventually as you see ;)
But you could just use the White windings for the mediator to work, one end on the positive rail and output end
both katcher & mazilli positive connecting to it and negative rail direct to power supply.
So as I have read you want to hook it up as original way, the Roman way :)
alot of tuning required. But the Ruslan way will be easier for you Nick :),
is what I am doing now. Roman's way will come in play soon enough. T-1000 will show it working too :).
A TL494 and driver is needed to able to tune it where it is. but If the mazilli's fixed freq is there already, that would be nice.
but what will be interesting to see is when you synchronize them with the mediator ;) with current setup.
See if it works out with a mazilli/royer circuit. But remember you need atleast a Tl494 & diver board.
Cheerz~
lacphong
GeoFusion,
It's good to hear that you're getting some positive results finally.  Can you tell us which schematic you are using for your set up that is working right now?
Thanks in advance.
Quote from: GeoFusion on May 26, 2016, 06:57:53 PM
Hi guyz :)
Nick,
Well there is alot of good news and alot still to test :) .
alot of tuning required. But the Ruslan way will be easier for you Nick :) ,
is what I am doing now. Roman's way will come in play soon enough. T-1000 will show it working too :) .
Cheerz~
Dog-One
Quote from: lacphong on May 27, 2016, 12:48:37 AM
It won't be too much longer, Geo will be saying:
"I'd be happy to burn your light bulbs out."
  -- Donald L. Smith - 1996 Tesla Symposium
