0 Members and 627 Guests are viewing this topic.
AlienGrey
Quote from: John.K1 on June 09, 2016, 04:52:11 PM
Well, if you mention H. M then you have to accept the fact that his device had been  working in area far from any broadcasting and electric lines.  Why do you think that Radio is only one source?  We are surrounded by cosmic rays , space electromagnetic waves, Schumann resonance, Whistler waves,  in the ground are the rivers of currents ,  etc and atc.  And if I will accept the fact ,that broadcast is the reason of functionality, would you be able to get from it 2 kW and more?? I don't think sooooo :) In the  far distance you can get some mW of it ;)  BTW- Ruslan is from Riga, FM band where ever you look :)
Eric Dollard quote if your coil is Full Wave and you use the ground as the antenna you get no loss but go too high and your cut off by the ionosphere. But then you have all this made radio toxic junk every where.
Jeg
Quote from: John.K1 on June 09, 2016, 12:25:57 PM
Hi Jeg.
In short what he says
1. Half wave coil has maximum current /minimum voltage  at the ends (longer coil A)
2. 1/4 wave coil has minimum current/ maximum voltage at the end (shorter coil B)
3.  So he connected the ends of both coils across the bulb
Thanks Jan
Aren't those two circuits look alike or what!? 8)
T-1000
Quote from: AlienGrey on June 09, 2016, 04:09:33 PM
When Akula came to Germany it wouldn't work, that's because we are mostly on FM band.
That looks like another barking on wrong tree.
What akula told me personally it was too high operating frequency in the Tesla coil for transistors to handle. So the large device ran inefficiently and was capable to light up only CFLs...
Jeg
NickZ
Quote from: Jeg on June 10, 2016, 03:23:09 AM
Thanks Jan
  Jeg:  That posted circuit is the Mazilli circuit, which I have been using for the magnetic induction circuit which was also connected to the grenade.
          There's no 6 kW out... nor is it free energy, either.
           In any case, I'll connect the inductor of the grenade to my Earth ground, and somehow connect the middle of the induction coil to a bulb, is shown in the posted diagram.
I may be able to do this soon, IF I get my needed IRF260P and 18v zeners, which I've ordered locally already.
     Is there a video of the above set up working, at 6KW???
