0 Members and 93 Guests are viewing this topic.
Dog-One
The concept shown in Nodir's document is actually quite simple and has practical
application.  I'll name this concept (which is also a component) a:  Coil-cap.
If you closely examine Nelson's RochaBoard, you will see it.  Look at those two
rather large electrolytic capacitors connected to the base of the TIP122.  From
a schematic, all we see are two capacitors.  Look again and recall how these
capacitors are manufactured.  They are strips of foil separated by a dielectric
insulator, then rolled up into a coil and stuffed inside a protective canister.
What we have is a self-contained RC tank circuit housed within a single component.
You might ask yourself how many Henry's does a 50V, 100uF electrolytic capacitor
have.  Trust me, it's not zero.  What do you suppose this device might do at
high frequency and would it be enough to bias that high hFE Darlington TIP122?
Now suppose you were a rather ingenious chap and made your own Coil-cap using
four sheets of metal foil with three layers of thin insulation between them and one
thick layer of insulation on the outside.  Roll the whole thing up.  Connect the
outer two foil layers to a signal source and the inner two foil layers as your output.
You have just made a variant of the device Nodir describes.  This method will
be more capacitive than inductive, depending upon how wide you make the
strips.  I'm sure by working with the geometry (strip length and width) a suitable
design can be had that will elicit the characteristics desired.  Is this what Nelson
did with his higher power device?   Or Kapanadze?  I do have my suspicions...
I think one of the limitations we put on ourselves is to see a capacitor or an
inductor as a discrete component.  They are not.  We can say an inductor is
a negative capacitor and vice versa.  The trick is to engineer our Coil-caps
properly for the application.  Motor/generator Coil-caps are no different as
Erfinder has made quite clear to me.  Once we get past this mind-screw, I
think we can actually make some real progress.
justawatt
Quote from: Void on June 17, 2016, 01:28:38 PM
The problem is that 'Roma Grits' AKA 'Andrei Bryukhovetsky' seems to be pretty closely following the standard M.O.
of an internet free energy scam. He stated to me in an email that he won't let anyone inspect his device in person first
to make sure there are no hidden wires or hidden power sources. I don't think any honest person would seriously expect people
to pay thousands of dollars for a claimed free energy schematic or device without being able to first confirm in person
that the device works as claimed without any tricks. However, free energy scammers use this exact approach all the time
to sell 'free energy schematics' and similar over the internet to gullible people. Also 'Roma Grits' wants people to send him the
money via Western Union, which is also typical of scammers since the person sending the money assumes all risk in sending
money via Western Union. At least Kapanadze and Akula have allowed other people to see their devices operating
in person. :) If people want to raise money to pay this guy 'Roma' or 'Andrei', or who knows what his real name might be,
then they should at least first pre-arrange with the guy that before any money is paid to him that he allow an independent
third party or parties (should be a person or persons with a strong electronics background and good knowledge of how tricks
might be employed in these type of devices) to inspect the device in person first. Anyone who refuses such an obvious necessary
precaution before payment is either a scammer or a delusional or a moron. :) The most probable is that they are a common scammer.
void
point taken ,i haven been in the free energy hunt since 8 years and i am an electronics engineer too.i have never seen how is it possible to get
free energy from cw-ccw like coil system like ,akula ,ruslan ,kapandze ,Roma device.
But i have seen true mechanical device making overunity power.
claim: https://www.youtube.com/watch?v=QabOJ3oZLi4 (from india)
From my exp i say ,high frequency coil cannot create these  high amps ,maybe no more than maybe 1 amps max .
if device is working ,their coil should be make 10 amp or more so these device's does not work on
high freq.
Note :
Akula's first device worked in 100 hz ,(info: from a good source)
All the kapanadze device worked in 50hz and 100hz range.(info: from a good source)
AlienGrey
Quote from: justawatt on June 17, 2016, 03:37:10 PM
void
high freq.
Note :
Thanks just a Watt, Great video, all we nee
d now is someone to do a kit ;)
Jeg
Hi Matt
The most probable for me is that coil-caps and other such unconventional combos like that, are for charge separation only, in a try to make a more usable form of energy. But before that, someone has to open the gates first for these charges to come in to the system. This happens by the "right" driving. What a right driving means? Well, as we have learned out of Acula's and Ruslan's circuits, a right driving has some standard ingredients.
1. A current source
2. A transformer's primary
3. A high frequency switch
4. Some art for combining all these three together.
Just for inspiration i bring back an old post of mine with some Tesla's quotes.
Quote from: Jeg on August 31, 2014, 02:46:19 PM
All taken from his interview on his work with alternating currents
1. Tremendous advantage to break at the peak of the wave... page 56
2. Damped wave is of advantage. With a gen of 1Kwatt it gives an activity of 5Kwatts. Page 62
3. If you have a continues or undamped wave 1Kw gives you only wave energy at the rate of 1Kw! Page 62
4. Those experiments with powerful' discharges were mostly performed in this way, with a few primary impulses and superimposed quicker  vibrations. Page 92
5. Working with damped waves we can produce wonderful effects. Operating with undamped waves we have to stick to the actual capacity of the machine. Page 92
The book that those quotes are taken from:
https://books.google.gr/books?id=KRg9HWakBmQC&pg=PA56&lpg=PA56&dq=Tremendous+advantage+to+break+at+the+peak+of+the+wave&source=bl&ots=0TnH_x7XAx&sig=tGNYuS-Rnrhd699dUFEY92IEzR4&hl=el&sa=X&ved=0ahUKEwihhrbz9bDNAhXMJsAKHR-eCg8Q6AEIJjAA#v=onepage&q=Tremendous%20advantage%20to%20break%20at%20the%20peak%20of%20the%20wave&f=false
PolaczekCebulaczek
about the concept of fusing current and voltage together
https://www.youtube.com/watch?v=lp-KOgU9n78
this is different method,edwin grey tube, but i can see some similarities...
