0 Members and 518 Guests are viewing this topic.
Grumage
Dear All.
Just for interest and in my opinion a better Royer oscillator circuit because it does not use a center tap. Look here.......http://4hv.org/e107_plugins/forum/forum_viewtopic.php?74096
Cheers Grum.
verpies
Quote from: Void on May 18, 2013, 03:46:02 PM
Although you can cut a wire length to about 1/4 wavelength for a given frequency, the actual frequency a coil will resonate at for a given wire length will be different than what that same wire would be resonant at if it were a straight wire.
That's true.
NickZ
  Just keep in mind that the object is not just to light a bulb or two at the end of the circuit, but to do so without using any power from the PS, or battery source. The CENTER TAP transformer be it e-core, ferrite rod, or iron laminate can help to make that happen. As akula mentioned that an iron core transformer would work even better than his air core does.  TK was showing a big old iron transformer, whether it was a step down or not I don't know. But, at least it was part of the circuit, and can be of use.
  You can see from the SR 193 video that his power supply meter drops to nothing, once the circuit kicks in,  when given the starting injection from the bump-start source. It may be possible for this to happen even without the feed-back path to source. That is still a question in my mind.
  So, Grum,  did you get a chance to view the Lasersaber coil tuning idea, that I posted previously?
  I was thinking of you, and your toroid core.
Hah...
NickZ said,
QuoteI don't think that Tinsels snake oil videos have anything to do with or relation to TK's several KW systems. And if so, then I would love to see it done even with 100 watt bulb. Snake oil, and all.
And then the very next post from anandml shows, in the left part of the circuit as the primary driver, the _exact same circuit_ that I used for the flyback driver.... and then Grumage links to the page with the _exact same circuit_ variation, no center tap, that I -- and many others -- use for our wireless power transmission systems. Except that I use IRFP260 for the flyback driver and IRFZ44n for the low-power wireless transmitter in my circuits.
Yes, the system that I showed lighting up the bulb underwater can easily transmit 100 Watts or more to an incandescent bulb with IRFZ44n mosfets. If I built it with, e.g. IGBTs and better capacitors and a bigger transmission loop.... I'm sure I could reach local power levels on the order of anything TK has shown. (And I don't believe he's actually shown 2 kW either, but maybe he did, using his hidden wires.)
So you can disregard my "alt.snakeoil" videos, which are presented in a light-hearted manner, but you cannot deny that many of the diagrams we've seen on these threads incorporate the exact same circuitry that I am using to make my effects. What you conclude about Kapanadze's demonstrations-- which somehow seem to manage to have the same output frequency, exactly and stably, as his home mains line supply..... is up to you, I guess.
verpies
Quote from: Grumage on May 18, 2013, 05:08:12 PM
If the split ± power supply is not a problem for you, then Great!
