0 Members and 69 Guests are viewing this topic.
MenofFather
Quote from: Jeg on June 27, 2016, 06:30:04 AM
Guys, what is your opinion on this? Seems that when thyristor conducts, output capacitor shortcuts itself. And right after, charges again though load and ground!
It seems like we create a sub-pressure for sucking charges out of the environment. Do you think that it would be more efficient if the below leg of output capacitor would be connected straight to ground instead of in between thyristor and load?  ::)
In RomaDivice seems no tyristor.  So maybe that schematic is not Roma divice schematic? And how he run 50 herc motor? And from were going control tyristor?
AlienGrey
Jeg
Quote from: AlienGrey on June 27, 2016, 03:37:58 PM
Tesla used a 1/4 wave inner coil and a half wave outer coil or you can use full wave
Hi AG
We see in many designs this self oscillating loops inside the main coil cores. Usually they are freely oscillating tank circuits tuned to the low KHz power signals. Their job is to act as a spring for the output coil, the moments in which primary shuts down. This way the inductive output kick becomes higher. A well designed system can work without them. But if you use this trick output becomes higher indeed.
Hi Menof.
Thanks for the info. I thought that this design was Roma's. Anyway. A spark gap in place of the thyristor will act the same i guess.
Tomtech29
HI>
- hard to believe that the person Ruslan says that all the hints are going to nowhere...
Here the translated text:
" Guys ! Wake up !!!!! Nothing he does not work to give 1000%. It fuflogon and impostor. I told all my lectures during that time, when I experimented and gave results on the general overview. But unfortunately, these experiments give a notion of how not to do. This is also a useful course. But I'm just not long ago began to understand what is happening in the coils and why it works. Alekseev is fully nonsense and many others do not hesitate to listen to this madcap: (This is sad!!! Learn the nature of standing waves and how the Tesla coil, and in what conditions. Then you will be able to accurately replicate and even create your unit and more powerful. That asshole exactly listen do not. it does not work this device with him and he nicherta not cooking. All that he says stole from my old explanations that were just as experiments. All they ask how I did it! Hands doing, head to think. Everything is possible find out with the help of experiments Akulin video. everything is there !!!"
increasingly difficult to verify what is true and what is not! Alekseev It does not have a working device is rigged!
... what do you think? T1000
T-1000
Quote from: Tomtech29 on June 28, 2016, 03:24:12 PM
If you stick to the sources of people who actually had OU devices the information will be clear. Won't trust any third party circuits in that case as they are leading nowhere.
Also I noticed people are getting confused about wire lengths on grenade. In short, the grenade first layer wire length divided by 2 is the half-wave. The opposite layers on one of the half need to match same wavelength but there are 2 issues where everyone have to deal with: the increasing number of layers require larger wire length and the other half of grenade under inductor plus earth ground extension also change the actual wave lengths.
To have standing wave between opposing layers I simply take wire length of the first layer and roughly calculate that wire length as full wave length. The goal is to have standing wave node on "hot" grenade end and anti-node on "cold" end leading to the ground. If you struggle on those terms understanding here is good read about it - http://www.physicsclassroom.com/class/waves/Lesson-4/Nodes-and-Anti-nodes
Cheers!
