0 Members and 93 Guests are viewing this topic.
Stela
Transformer No Magnétism kapanadze?
https://www.youtube.com/watch?v=XmxAZ0ybE3Y
Find resonance frequency Tesla Coil (FRENCH)
Little tutorial on how to find the fundamental resonant frequency of his Tesla coil.
https://www.youtube.com/watch?v=M_6bK4MvUM0
AlienGrey
Quote from: NickZ on July 02, 2016, 09:37:47 AM
  AlienGrey:
  It's not what you learned about in school.  As each self runner is running at a different frequency.
  No two self runner are working at the SAME frequency, yet they all work,  (IF true).
  I think that it's the relation of the two frequencies that's important, as there doesn't seam to be single magic frequency to tune to.
  I suppose that what is being called "dancing", means vibrating, at the right frequency match.
  Even on Poma's simple kacher circuit device, there are two frequencies, "dancing".  And that's the rub.
1/. we had a wire going down the length of the long classroom with wires connected to small bulbs every so often and when the right frequency was hit they would all come on.
2/.True apparently but I wouldn't be so quick as Tesla found some frequencies better than others where he found peeks ant troughs in power and also the same in healing and darker energies when tested on plants (borderline Technologies) the late Bob Beck's research.
AG
NickZ
   What Tesla found was that different frequencies produce different effects, such as the wide white streams of Aether, which would light up the room. The purpose of the TL494 is to adjust the two coil to work together to provide for the best output. The frequency bandwidth is tiny, so it's easy to miss.
   We already know at what frequency our devices should be running at, according to just how long the grenade's output coil is, 37.5 to 40m long.
The inductor should be matched to the output coil, and the Kacher matched as well. Some how it doesn't seam to work out that way, for us. Or at least for Itsu, and others that have tried to tune their device in that way. All that Ruslan does is to turn the TL494 pots.
I don't know just how he figures and tunes the Kacher's matching frequency though. If we knew the Kacher's secondary coil size, it might help to tune in on what frequency it's suppose to work at.
John.K1
Quote from: NickZ on July 03, 2016, 09:27:25 AM
Hi Nick, I think it is just about to add or remove some turns from the Tesla coil to get the frequency you need?  Just it doesn't work linearly. You take of some turns and nothing will change and with the next turn removed the frequency will jump. In other words, it has jump characteristic. I think to calculate kacher frequency it is very hard-so many parameters to play (self inductance, self capacitance, the antena plays big role too- its size and distance , kacher's components used etc...)
Regards,
