0 Members and 96 Guests are viewing this topic.
GeoFusion
Hi Guyz :)
Well I would want to say something.
We could all start on the 37.5 meters of grenade wires or 40 meters long wires. does not matter.
But only If you want to drive it on another freq.
It will all vary to other resonant frequency ranges.
when that is done.
make sure to find the Resonant frequencies of series resonance with cap part on yoke to bifilar on grenade
and add tesla coil pulses to see gain.
In between all of this, the MOST IMPORTANT.
You need to see Synchronization & effect befor even removing wires to adjust freq and more.
no matter  if the tuning is not prefect yet, this one of the first steps in my experience!
If you don't see this, then there is something wrong with circuits or some connection missing.
you will need to see a small or big gain on the load ( small bulb at output part )
when kacher is connected with pushpull in synch.
I have let some buddies make nice PCB's of the kacher and Pushpull. They work individually great.
They are not working the same as my old kacher circuit nor pushpull for achieving effect.
It does not give effect, so the slightest change in circuit connection can make differences.
It will go under investigation to see where it does not.
SWR (Spin Wave Resonance)
is what is happening here as what T-1000 has said many times
And Tesla coil or HV coil to pulse is for the acceleration.
Check this out
some guy replicated synchronization and effect,  simple.
https://www.youtube.com/watch?v=ivWeWzkoPI0
Cheerz~! ;)
NickZ
   Geo: I was hoping that you'd show us how your circuit self runs, by now... not just how there's not even any OU, with or without the mediator coil.  You would be more convincing if your device could self run.
   The posted video has a very weak Kacher circuit, and an even weaker induction circuit. The fact that the bulb lights up slightly with the Kacher adding it's output, is not convincing. As I doubt that it can self run, or even obtain OU with that weak output barely lighting the bulb.
  I also doubt what T-1000 mentions about SWR, as well as what Wesley mentions about his electrostatic pump theory, (pumping electrons), from the ground or from where ever, concerning the true cause of a self running device.
    Spin waves, electrons, moving electrons, etz...  That is Not how Tesla, nor Kapanadze would explain what is needed, or the mode of operation.
  I personally don't care about the HOW it can happen, as I haven't seen it happening at all, as yet.
   First thing is to obtain the "effect",  not just by showing lighting bulbs a bit brighter, but true OU, way over OU, instead.
Such as with the Poma device. It has No separate induction circuit, no complex nano pulser, TLL, and no separate mediator coil needed.  If true.
  Possibly Poma's summator coil is doing the same function as your mediator coil.  Or not?
NickZ
Quote from: John.K1 on July 03, 2016, 04:46:55 PM
Hi Nick, I think it is just about to add or remove some turns from the Tesla coil to get the frequency you need?  Just it doesn't work linearly. You take of some turns and nothing will change and with the next turn removed the frequency will jump. In other words, it has jump characteristic. I think to calculate kacher frequency it is very hard-so many parameters to play (self inductance, self capacitance, the antena plays big role too- its size and distance , kacher's components used etc...)
Regards,
   Yes John, I've done that. I've added and removed turns until my Kacher's secondary looks like a salad, all a bunch of pieces, soldered back together now.  No magic frequency in site.  Even after adding or removing ferrite pieces inside of the former tube.
Which can vary the frequency by as much as 1mHz.  And still no cigar.
AlienGrey
Quote from: NickZ on July 03, 2016, 07:27:30 PM
yes but ! 'how' did you assemble the grenade coil ?  and how much wire in on the windings ?
NickZ
    AG:
    My grenade coil was wound exactly as was indicated previously.  Grenade 168t,  37.5m long,  48,48t, 24,24t, 12,12t
                                               The inductor (1/2 of the output coil) 18.75m long. I can't remember the number of turns that it took, but was about 2.3 layers worth of turns.  Not the 1/4 ratio,  10m, long, like Ruslan is suggesting now.
   I noticed that when I previously added more turns to the inductor coil, it lowered it's output.  So, maybe 9 to 10m may work better than the 18.5m size, to help sync the frequencies. I'll try that sometime, to see it there is any difference. For better, or worse.
   At one point I was able to light 2 100w bulbs, just from the Kacher's output, at the grenade's output coil. Without connection from that grenade coil to the yoke. Just from that 168t coil to the bulbs, and the ground line.
  But, the stronger the HV sparks, or streams, the more damage they can do to the more delicate components. That's where my 37.5m Earth ground line into my water well, comes in to save that from happening. Otherwise without that ground line, there's HV running everywhere and on everything. And that's what fries things out. That does not happen to the same extent when using a good outside ground connection.
