0 Members and 53 Guests are viewing this topic.
SeaMonkey
Quote from: NickZ
   Yes John, I've done that. I've added and removed turns until my Kacher's secondary looks like a salad, all a bunch of pieces, soldered back together now.  No magic frequency in site.  Even after adding or removing ferrite pieces inside of the former tube.
Which can vary the frequency by as much as 1mHz.  And still no cigar.
Precisely Nick!  And, there won't be any Cigar.
Not to say that all of your work is without some benefit.
Knowledge is a valuable commodity and you're getting
a good amount of it.
Any day now it'll come to you that Free Energy is an
elusive carrot on a long stick.
AlienGrey
Quote from: NickZ on July 03, 2016, 11:37:41 PM
    AG:
    My grenade coil was wound exactly as was indicated previously.  Grenade 168t,  37.5m long,  48,48t, 24,24t, 12,12t
                                               The inductor (1/2 of the output coil) 18.75m long. I can't remember the number of turns that it took, but was about 2.3 layers worth of turns.  Not the 1/4 ratio,  10m, long, like Ruslan is suggesting now.
   I noticed that when I previously added more turns to the inductor coil, it lowered it's output.  So, maybe 9 to 10m may work better than the 18.5m size, to help sync the frequencies. I'll try that sometime, to see it there is any difference. For better, or worse.
   At one point I was able to light 2 100w bulbs, just from the Kacher's output, at the grenade's output coil. Without connection from that grenade coil to the yoke. Just from that 168t coil to the bulbs, and the ground line.
  But, the stronger the HV sparks, or streams, the more damage they can do to the more delicate components. That's where my 37.5m Earth ground line into my water well, comes in to save that from happening. Otherwise without that ground line, there's HV running everywhere and on everything. And that's what fries things out. That does not happen to the same extent when using a good outside ground connection.
Sorry thought you were serious, have fun and good luck, over and out. ;)
NickZ
     AG:
   Sorry, as well.  I thought that YOU were serious.
   You are assuming that I didn't measure the total length.  I did. But, the details of it's build are not very clear now, as it was done a while back.  It's easy to cut the right size wire, and to cut the inductor at half of the output coil, or 1/4 (now).
  You say that I'm starting from the bottom, look at my 3000 posts, here. And that I need help to cut the wire to the right size?
  Radio guys know how to build self runners?
  I'm not living on an Island.  I live in Costa Rica as I've previously mentioned, which is not an Island.
  Pic below, of my town.
   Once I get the induction circuit running again, I'll change the inductor to 1/4 of the output coil's size. And see it that works better, or not. The current inductor is  working well for now, as far as transfering power to the output coil from just the Kacher to partially light a 100w bulb.
  I use the same type of sink drain tube 1 1/8 inches as the former, with the previously stated turns on it.  I made all this about two years ago. Not starting from the bottom, I've also added and removed turns on the output coil at different times, as well.
   SeaMonkey:  Are you assuming that there is no free energy to be tapped from the ambient? Simply because we have not hit on it yet?  There's too many self runner out now to assume that it's all just fakes, or wishful thinking, with no results.
  You should also be aware of Tesla's thoughts, and experiments. Concerning the Aether and tapping it's potential.  I don't think that there is anything illusive about what he says, or has done.  Except about his electric car.  That is still a tightly held secret.
   I'm not into this just for the knowledge, as knowledge without practice, is well, you know...
I'm into it to power my house, car, bikes, etz...
  If this were simple, it would have been common knowledge long ago.  It's not simple. It's hard to get the sought after results.
You have to be Russian, drink vodka, smoke, and wear magic shoes...
  Not trying to be too serious, just trying to have some fun.  For me this is fun, and exciting.
SolarLab
F.Y.I.
SWR Clarification:
Generally, when working with Electromagnetic Waves [EM, Radio Frequency (RF), helical coils (slow wave cavities)], SWR refers to "Standing Wave Ratio" or VSWR {Voltage Standing Wave Ratio}; |Vmax/Vmin|.
Refs: https://en.wikipedia.org/wiki/Standing_wave  - click on the right-hand figure and follow the ">" for animated cartoons;
Also: http://hamwaves.com/antennas/inductance/corum.pdf  - "RF Coils, Helical Resonators and Voltage Magnification by Coherent Spatial Modes," Corum and Corum, 2001. Detailed analysis with math. Use PDF "Find" SWR or VSWR.
"Abstract - By modeling a wire-wound coil as an anisotropically conducting cylindrical boundary, one may start from Maxwell's equations and deduce the structure's resonant behavior. Not only can the propagation factor and characteristic impedance be determined for such a helically disposed surface wave-guide, but also its resonances, "self-capacitance" (so-called), and its voltage magnification by standing waves. Further, the Tesla coil passes to a conventional lumped element inductor as the helix is electrically shortened."
Also: http://www.arrl.org/files/file/Technology/tis/info/pdf/q1106037.pdf - "Understanding SWR by Example," Walraven, QST 2006. Overview but gives Smith Chart VSWR/SWR relationships.
Spin Waves, to a great extent, are still somewhat ill defined but apparently relate to excitation's occurring in magnetic lattices - magnetic materials (equivalent quasiparticle point of view - a.k.a magnons; boson modes of the spin lattice that correspond roughly to the phonon excitation's of the nuclear lattice, or whatever!). Spin Wave Resonance might also have the acronym SWR, however I have yet to see that.
Ref: https://en.wikipedia.org/wiki/Spin_wave
Have a nice Summer everyone, maybe by this Fall things will start to gel a bit more! ... BTW, CAE EM simulations are progressing; very slow but steady.
FIN
AlienGrey
Quote from: NickZ on July 04, 2016, 09:53:53 AM
     AG:
  I'm not living on an Island.  I live in Costa Rica as I'm previously mentioned, which is not an Island.
   SeaMonkey:  Are you assuming that there is no free energy to be tapped from the ambient, simply because we have not hit on it yet?  There's too many self runner out now to assume that it's all just fakes, or wishful thinking, with no results.
1.5 in pipe ! difficult to get precision hairpin bends with that dia and 2.5 mill cable.
Costa Rica, nice view but got idea of a watery where you are ! Not far wrong by the looks of it in your photo!  https://en.wikipedia.org/wiki/Costa_Rica
