0 Members and 37 Guests are viewing this topic.
NickZ
  What I'm focusing on here is the Akula 0083 self running circuit. I'll let you show us how the circuit that you have works, when you can.    Akulas latest design outputs enough to light 1150 watts worth of bulbs, with no input source, once started. That enough for me to have a whack at it.
  Most of the oscillators work about the same, the low voltage parametric oscillators, or higher current ones are just switching circuits, some more efficient than others, depending also on capacity to do work.
I don't think that the magic lies there. But, what the switching circuit does to effect the coils, when incorporating magnetic resonance into it. There lies the trick, or two.
Quote from: NickZ on May 18, 2013, 08:05:43 PM
You mean that the circuit is CLAIMED to light all those bulbs with no input source, once started, and I am telling you that it cannot. Take your whack at it all you like, you will never be able to produce his effects in the way that he claims to be producing them. However, if you forget his theoretical bullshit and simply try to produce the EFFECTS by the simplest means possible, you will be able to do it, and I and others have given you hints as to how to do it. What you do next is clearly up to you, and if you are successful, I'll apologize in public, admit that I was wrong and go away and hide while the Revolution occurs. But if you are NOT successful after giving it a good whack or two, say by this time next year.... what will YOU do?
T-1000
Quote from: TinselKoala on May 19, 2013, 05:48:05 AM
The first attempt most likely will fail to replicate but if you keep trying you will succeed. As far as I personally know, there are hundreds of people at least in Russia who got self runners just they did not want to go public. In regards to effect it all boils down to same principles as in NMR in various ways - directly on wire, on magnetic field and on matter itself. It is only matter of time when this stuff will be known to every single man in this planet.. ;)
Сергей В.
Quote from: T-1000 on May 19, 2013, 06:01:03 AM
Yes T-1000 told TRUTH !! Belive or not Know or not ENERGETIC REVOLUTIN HAS STARTED !!
For example several generators like this light variant from 20KWatts run free electricity in Russia!!
And not only in Russia. In many countries. We are at the begining on the Biggest Change in Epoch here on this planet. After that Nothing will be the same like was.
Dynamic is Cosmic Way of Reality!!
Hoppy
Quote from: Сергей В. on May 19, 2013, 07:03:39 AM
What is the self running power rating of this 'light' version you show in the photos?
