0 Members and 157 Guests are viewing this topic.
NickZ
  I've mentioned that I've always used magnetite magnets in the yoke core. I'm not interested in making my own cores, as I have several Tv yokes, which have produced good results.  I'm also not convinced that the homemade cores are indispensible, to obtaining a self runner. We don't even know any details of those homemade cores, or which devices they were being used on.
   Itsu is always on the bench, but not wanting to waste more time unraveling riddles.
   Geo, has not mentioned just what his results are, after rebuilding his TL494 board. But, I don't see any self runner, from him, either.
   So, for now I will wait to see if there are real and positive results, before continue on.
   The Poma device is what I'm looking into. And seeing if I can make the Kacher/grenade work in a similar way, but, without using the driver circuit of the induction circuit.  Again, it's just another riddle.
   Most guys have given up on the Akula/Ruslan replication, a while back.
apecore
Yes i understand Nick,....Wait and see.
I'd prefer a more active approach then just sit and wait until somebody is given us the clue..... i think that that won't be happen.
So just sit and wait ,........ will result in another 5 years of no progress.
I don't take factson belief off persons,....  i guess that is also how you see it.
Or please explain why you are convinced about yyour TV cores?
These are i think not insidethe grenade?
So let us not be convinced that the self made core is something what could be minor.
We are all aware that one or a vew puzzle's are missing.
After all,....  the tuning and start_up part what more and less is explained by Ruslan is in my opinion to be considered as "complete". (I have seen no comments on that tread)
Finaly there are in my opinion two aspects for good result;
1- Complete configuration(hardware)
2- Method of tuning to get it started (Tuning & start_up)
At this moment we struggle about the hardware,..... so the tuning won't give result.
Lets spend some post about the possible specs of the selfmade cores?
Greetings
NickZ
   apecore:
  The reason that I think that there is nothing wrong with the yoke core that I've used is because I can light up to 7 100w bulbs with it. And producing more light output (lumin) levels, than anyone else's replications, other than Akula/Ruslan. Yet, it is not free energy, as yet.
   You can try to make your own cores. No they don't go into the grenade coils, as those are air cores.
But, I do use ferite inside of the grenade, for both the Kacher part,  as well as in the air core for the induction circuit section.
   What Akula may have used to make his cores, I have no idea, nor if they were even used for his second self running video device.
   In any case it's the Ruslan devices which I'm interested in. As there is more info, schematics, videos, and descriptions on it.
   Maybe T-1000 can ask Oleg about the home made cores, and if Ruslan has actually needed to used them, or not, to produce 4000w watt output for his last device. It seams to me that Ruslan showed his first device, the Dally replication was not using a yoke core. But, then in later devices he was using the 3in yoke cores.
   I've already spent a couple of years on this device, built up in my own way.  But, I'm never giving up. Nor did I say I would just wait and see.  I will continue,  there is not a day that I don't work at the bench. But, some of these unknowns need to be answered, as well, which is what I'm up to now.
AlienGrey
Quote from: apecore on July 09, 2016, 10:41:49 AM
Greetings
Funny you should mention hardware, let's focus on the grenade coil and it's other winding the primary
from what I understand if the grenade coil is not wound correctly you get nothing or it gets hot and melts the pvc tube.
has anyone got the latest CORRECT WAY possibly with a diagram with measurements on how to wind both windings.
AG
apecore
AG,
Good point,.. there is also some confusion about the grenade configuration..
Most configuration (drawings) about the grenade are 37.5m and the primary 18.75...  (4:2)
Now its told that it has to be 40m  and 10m.... (4:1)
Makes a lot difference as Nick already mentioned.
The difference in length is not critical there only the frequenty will be different.
But the change in the primairy to 10meters is mayor,....that means we go from half wave to quarter wave.
There must be a explanation about this change.
It is a mayor change because with half wire lenght it is not clear if we have to make one or two layers?
About the winding direction i think next link (there is a picture of the grenade) is clear about that.
Also i see inside the grenade a strange coil/ winding..... (braun wire)??
http://realstrannik.com/forum/ustanovka-kulabukhova/169-analiz-ustanovki-s-kacherom?start=954
