0 Members and 553 Guests are viewing this topic.
apecore
Quote from: NickZ on July 31, 2016, 10:23:54 AM
  AG:  You mentioned that the former tube that I use is strange?  It's the same sink drain tube that Ruslan uses. So, it's not strange at all. It is the recommended one shown by Ruslan.
  My grenade windings are also the recommended size. 48,48, 24,24, 12,12. 168 turns total for the output coil, and 18.75 meters long for the inductor coil.
When your pipe diameter is only 1.5inch your output coil length is only 26 meter...... (using the 2.5mm2 solid wire with isolation)
so i guess no 37.5 meter coil length?
NickZ
  No, it's what I said it is, and not 26 meters long.  Nor do I use a 1.5 inch PVC pipe.
Nor do I use solid wire, but the stranded wire, like Ruslan/Akula use.
AlienGrey
Well! Nick Z thank's fo the update and correction to the information. let's hope you get to the bottom of the problem Geo was saying in one of his videos that his grenade coil was getting quite hot (but that's not the diodes) if your really stuck for some fast diodes I have 4 I recovered from a UPS they are good if your stuck i can post them to you, if you want.
Anyway good luck.
br549
Quote from: GeoFusion on July 26, 2016, 03:16:57 PM
Hi guyz
This is Vasmus schematic of his device, One of the versions.
Something for the forum and many want to try it well here goes.
but I will say there is one thing missing, and is not connected to sumator.
what is it :)?
Hi Guys:   I had a question about one of the components shown in the Vasmus drawing. L3 appears to be a coil, but why is it drawn at an angle?      Thanks ahead of time for any feedback.
AlienGrey
Quote from: br549 on August 02, 2016, 09:09:18 AM
this is another schematic version, any use ?
