0 Members and 543 Guests are viewing this topic.
GeoFusion
Hi guyz
NickZ,
I have posted the diagram, it shows you how it's wound and where it's connected.
It's all ferrite core. Vasmus used some strip like ferrite bundle to use it as
a toroidal transformer. There might be differences sins the ferrites are spaced with material.
But ....in this video you can see some guy using the coil configuration in comparison to a standard transformer.
https://www.youtube.com/watch?v=4-flVbCreIM
Yes, in Vasmus device this works as same as what we are referring to as a Mediator, 1 transformer with 90degrees winding with it
with other separate winding(s) that will supply and convert energy at the same time with Synchronization for the circuits connected.
btw, those diodes that overheat are the part of the ZVS circuit?
Remember you will need a good PWM to continue, it's necessary and will be fun.
Fixed frequencies wont do.
AG,
Which ones are you referring to as TX and RX? please let me know :) so we can be on the same page.
For what is missing is the Resonator.
Which is another circuit which is in between Tesla and 90 degrees coil with receiver coil, it will be also
connected separately with amount of turns to the Sumator (mediator)
Tesla and Resonator need to be in Synch. for it the produce.
Yes that Schematic can be used as referrence too.
See pic below.
br549,
He has drawn the coil direction on schematic such in a way for him as reminder that it's the
90 degrees coil laying down in between. ( The Horizontal coil )
See Pic below
To clear up some confusion, Recently I have personally tested 3 variations of grenade coils lengths
and to synchronize each one in test conducted and all worked with different results but got the same Synch. effect working.
Just A different resonant freq is to be found each time with different lenght ;).
Just follow the resonance when you reach it. You all determine the lenghts of coils, but be aware it needs to stay
in the range that the circuits could handle.
Cheerz~
apecore
Quote from: GeoFusion on August 02, 2016, 12:30:44 PM
Cheerz~
Geo thxs for clearafication about the grenade coil length and the resonance adjustment.
So wathever nickz has on his bench he has to ensure resonance 8)
Resonance of kacher/tesla, grenade output coil and inductor is something to perform generally.
But what is your perception about the winding configuratiin of the grenade coutput coil.....
Length is devided in winding configuration
I m focussed now on the interaction of the inductor on the output coil and therefor the way the pickup effect wil be performed by the grenade coil.
Did you in your 3 different configurations used fixed coil windings or did you adjudt them in order to use the same former diameter?
This variable would effect the field configuration..
Meta
br549,
The 45 degree angle has significance. It may be the 90 degree coil relative to the other standing coils and I also know that a 90 degree rotation of an electron is considered, in Science, to be the definition of a dimension. However 90 degrees in 3D is 180 degrees in 4D (where the real energy is).
So, when we double 90 to 180, we can also halve 90 and arrive at the same 4D energy at 45 degrees...one half of 90, this time....so 45 degrees might indicate real coil position, in 3D, to access 4D energy.
Remember the 45 degree dual Utron energy cones on Otis Carrs levitating discs and the 45 degree rotor on Babbcocks motor. Both access 4D.
Also if you want to know where the 4D unified gravity energy is, in your schematic, its in the center axis of the tubes, right down the middle....so you either have to run your wires thru the middle of the tubes or you have to make the tubes circular and trap the gravity beam inside the  tubes and tap it like that. Its just a matter finding a method of tapping the 4D unified gravity beam and then bringing it back down to use it as E and M. This is also the purpose of the 90 degree crossing wires, between relative tubes.
AlienGrey
Hi guyz
AG,
See pic below.
Just A different resonant freq is to be found each time with different length ;).
Just follow the resonance when you reach it. You all determine the length of coils, but be aware it needs to stay
Cheerz~
Geo that's so far the best photo I have seen !   To me, I would say the coil on the left is the TX tesla coil and the one on the right is the RX 1/4 wave receiver, you might well get some power gain out of that coil but it's not enough for us novices to get anywhere with without some help.
Have you got a pointer to the Vasmus forum ???????????   Please ?
NickZ
  Geo,  I've connected the yoke secondary coil output to a full bridge rectifier and capacitor, which then goes to the input of the Kacher circuit. And, I've seen the amplification effect three times now.
  As the Kacher is being feed by the yoke's main output coil  (28t) coil,  that's what heats up the rectifier diodes, as there are plenty of amps running there. The grenade output coil (168t) is isolated from any direct connection to the yoke, and just goes to the bulbs, for now. Later to the PS, and then back to the input. That's the plan...
  I'm wondering if I double up on the IN5408 diodes that I use on the rectifier, if that will help with their heating issue, or not?  Your thoughts...
   I've shown on my videos just how I tune the ZVS induction circuits to each other, and also to the Kacher circuit, using ferrite and magnetite.  So, there is some control over the frequency, as the frequency is not fixed, like you think. Same with the Kacher circuit, when using ferrite pieces inside of the former tube.  But, the coil windings (turn counts) etz, need to be correct in the first place.
   I will obtain a TL494 board when I can, and some mosfet drivers, snubber circuit parts. etz...  It just takes me forever, as local parts not available, and internet purchases and shipping are not an option for me at this time.  And, I'm still looking for commercial alternatives, as well.
   So, tell me if your "effect" has enough amplification gain to allow for self running, or not. Or at least, what's going on with that.
