0 Members and 109 Guests are viewing this topic.
MenofFather
Quote from: apecore on August 09, 2016, 03:04:07 PM
Thanks Nick,.
I hope itsu can summerise about the yoke.
Second i hope menofather will give some more details because it is in my opinion the basic system of how that and our system works.
I will try to give it a shot if he delivers :D
all detail sems be on this threed. in russian forums also is many schematics how make that tesla work with brakes. then tesla run with brakes, it not burn from 100-120 volts. and it primary can have 4 turns, not 2.5 or3.
but if for you is that to dificul, then you can try with kacher without brakes and maybe use schematic topruslan7 search in google that picture.
MenofFather
Schematic to build tesla coil with brakes.
If using 24 volts, then for primary tesla can use 2 turns. If 150 volts, then 4-5 turns. In pack can try use 2-5 pulses. For smaller voltage can try use more pulses.
apecore
NickZ,
Thanks for thelink to Itsu's video,...i just purchased my missing components to build the yoke driver.
It is indeed as menofather says the Topruslan 7 version as wich i now wil replicate.
I attached it,.....i guess your setup is also based on this version?
Question about the yoke:
You mentioned using electric tape on the yoke half,......does the yoke has to be broken in two parts?
Also not clear for me is the torroid dimensions..(you mentioned minimum 3 inch),...  i purchased a 102-65-25 torroid, this must be good enough?
The other thing is that i will use for the secondairy 6mm2 stranded wire instead of the mentioned (in the shematic attached) 4mm2.
I hope this won't be a mayor deviation?
These purchased components will arrive tomorrow or the day after tomorrow,..  so then i can start winding the yoke and see if the system stays in resonance when yoke connected ,.........and hopefully i can lite some bulbs as you already showed.
I d like to see if both devices are acting rather the same?
That will be my first next step.
Related to the shematic from MenoFather, i also purchased that components.
Just like to see whats happen driving the tesla in that state,   related to the bulb test.
So MenoFather thanks for the information,....  i wil come back on that :)
Another thing i have some questions about the choke wich is used in the main output,.....can someone clearify on that?
For the expected output it should handle about 10Amps i guess?
Perhaps it can be homemade?
apecore
Hereby the resised schematic as mentioned in the lastpost
NickZ
  apecore:
  The yokes that I've used for this project all come in two halves, with a clip that joins them together. The smaller than 3 inch size do come in one piece.  But, I would use the 3 inch or bigger tv yoke cores. The 4mm stranded wire that is on the schematic is the one to use, but 6mm will also work for the three turns coil.
  Some of the yoke clips are magnetic, and others are not. If magnetic, it's probably best to not use the clips, and just tape the two halves together, but with paper or tape separating them from touching.
  No, my device is not based on that schematic or device, but on a previous simpler version made by Ruslan using the kacher circuit that I posted, and a different push pull driver.
  Here's the link to the version that I'm working towards, but basically they should all work in a similar fashion, or mode of operation. Although now, his latest device is shown lighting 4000w worth of bulbs. At least partially.
https://www.youtube.com/watch?v=eFVsXUsn4Uo
  It's great to hear that you're able to get all the needed parts, or at least ordered, for the push pull driver.
