0 Members and 93 Guests are viewing this topic.
AlienGrey
apecore
Quote from: AlienGrey on August 11, 2016, 07:41:09 PM
Have a look at this little gem then !
https://www.youtube.com/watch?v=vDp7bH0G7XA
AG,
It seems the Don Smith device is working.
Oef......again a new project on the bench.
MenofFather
Quote from: apecore on August 10, 2016, 02:41:07 PM
NickZ,
Thanks for thelink to Itsu's video,...i just purchased my missing components to build the yoke driver.
It is indeed as menofather says the Topruslan 7 version as wich i now wil replicate.
I attached it,.....i guess your setup is also based on this version?
Question about the yoke:
You mentioned using electric tape on the yoke half,......does the yoke has to be broken in two parts?
Also not clear for me is the torroid dimensions..(you mentioned minimum 3 inch),...  i purchased a 102-65-25 torroid, this must be good enough?
The other thing is that i will use for the secondairy 6mm2 stranded wire instead of the mentioned (in the shematic attached) 4mm2.
I hope this won't be a mayor deviation?
These purchased components will arrive tomorrow or the day after tomorrow,..  so then i can start winding the yoke and see if the system stays in resonance when yoke connected ,.........and hopefully i can lite some bulbs as you already showed.
I d like to see if both devices are acting rather the same?
That will be my first next step.
Related to the shematic from MenoFather, i also purchased that components.
Just like to see whats happen driving the tesla in that state,   related to the bulb test.
So MenoFather thanks for the information,....  i wil come back on that :)
Another thing i have some questions about the choke wich is used in the main output,.....can someone clearify on that?
For the expected output it should handle about 10Amps i guess?
Perhaps it can be homemade?
it inductance 100 microhenries.
NickZ
  Actually the posted schematic TopRuslan 7 is the one that I'm going to be replicating. Once I can get all the push-pull components. That posted schematic (below) does use the same Kacher circuit that I'm currently using, also.
   The TL494 board can be bought ready made for $8, or so.  MUR1560 bridge rectifier board can also be purchased ready made for about the same price. Itsu suggested using the Ucc37322 chip for the mosfet driver. So, that is the one I'll be getting, if I can find it.
apecore
Quote from: NickZ on August 12, 2016, 02:23:50 PM
Ha Nick,
Good to hear that you build it yourself too.
We will have to indentical replications,...  this has some advantage while testeing etc.
I have recieved my 80% components whitin a day,....  so i already make the TL494 circuit.
I ordered at Farnell but discovered that TME is even 50% cheaper on a lot of components f.i. the IRFP260M costs 3,44 EURO at Farnell and  1,41 EURO at TME.
Just to consider.
Tomorrow the other parts ae coming,....  kooling and stranded wire push-pull part etc.
I use the originally chip TC4420 chip for driving the mosfets.
Itsu refers to next link,...  here he tests his yoke driver with a lossless clamp setup,... considering his work i think it is the best to use that setup.
No snubbers circuits etc needed.
http://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg475512/#msg475512
So i will replicate Itsu's driver setup also the way he soldered the drivers at the mosfets. It is good to see in the video how he did it.
Attached some pictures as you can see how it is made.
Further some changes i ve made;
I changed the tesla coil because in the shematic 0.8mm wire is used,... mine was 0.5mm and i have now used 1.0mm wire, 50mm pipe and 185 turns.
The choke is approx 100uH and is made by 36 turns in 3 layers on a 80mm pvc pipe (wire solid 2.5mm2).....  no core used... (not yet)
Caps for the load are 3 times 3uF/1000V film capacitors
The yoke (because the stranded wire not yet available) i wound it with stranded 4mm2 28 turns and als the 3 windings (there are 4 i see now) also solid 4mm2.
I hooked it al up as shown in the shematic but no bulb activity yet as you shown lately.
Maybe (but i think not) the reason is that my inductor is 9.4m instead of the 18,75?.... i will make a 18,75 version to.....
Now i use as power supply to car batteries,....two 100Ah,...... so lots of testing can be done before charging.
Some other issue,..... i am thinking about;
You mentioned that the tesla coil as to be as close to the output coil as possible...... a reason why could be thath the generated magnetic field coming out of the top has to be absorbed by the left part of the output coil. So this could also be a tuning parameter?
This al has to be optimal before starting the inductor part i guess.
