0 Members and 170 Guests are viewing this topic.
apecore
Quote from: seychelles on August 17, 2016, 02:57:03 AM
MATE
Seychelles,...do you also have a translation of the text wich is part of the shematic?
It will help to understand the basicd
Thanks
AlienGrey
How it works ;)  it's magic, Translating Russian into to English, the cures of Babalon perhaps. Try Google translate then select Russian download the keyboard and type it in but it won't tell you how it works ;) You will need to know how stuff works to be able to solve that one, but may I suggest you work your way through this database from page one you will  find it a very good learning curve.
regards AG
apecore
[quote author=NickZ link=topic=12736.msg489944#msg489944 date=1471376793
  Perhaps Itsu may want to step in and give some advice and ideas concerning tuning for the various frequencies, and so forth.
   As far as the sync between the Kacher and the induction circuit...  It may not be right at 1/4, 1/3, or 1/2 wave, like we've heard. But, that's what we'll have to figure out. And, it may not be the same, for the different replications being tried.
   But, it's there, somewhere...
   apecore: You might also want to check the videos on YT by our member here, Tomtech29.
Like this one below,  he has several more, as well. And get up to speed on what's been tried by the different guys here.
  https://www.youtube.com/watch?v=7m7TVIKrDno
[/quote]
Nick,
Last night in burned one mosfet from the yoke.
During tuning with the potmeters i heard my tesla making noise...seems like AM radio.
Bulb lightning and Amps were going up and down and so on.
Could it be HF disturbing my circuits......it gets worse when i touch the multiturn potmeters from the TL494 circuit.
I will see if there is a bad grounding or something like that.
By the way....you posted something about sync the kacher and the push pull...simething to figure out.
What is your suggestion...i propose we make a simple plan doing the different frequenty tunings together so that we can confirm results etc.
But first i think we have to make a clear bottom setup....i see different approaches posted....last circuit the kacher is powered by the 28 turns yoke.....and output coil is complete electric isolated from yoke...
Maybe something to be figure out first before we do the frequenty tests?
Tomtech29
Hi.
apecore
The more circuits on a spider leads the greater the risk that the systems are prone to inducing (gate transistors and signals must be without HV pins.)
- so take into consideration that the radiators attracts radiant energy with Tesla coil, and everywhere you have differences of high POTENTIAL all this raises (and the clutch as a microphone to speaker)
a bad example.hmm / ground transfers part interference is deposited on the current something somewhere spark jumps and goodbye equipment - welcome to the autumn of the Middle Ages.
the cause may be different and for example, saturation of one-half of a ferrite core (through which magnetic flux was too strong) and one half of surrendered bumm zzz.
How can something advise is do not concentrate to achieve high efficiency heaters! because she did not have a high weld current :D
as you can see in the movies is a circuit of the coil and capacitor sets in motion the alternating magnetic field collected energy from the collector is constant See how the charging of the capacitor by the diode rectifier to ground.
pulse capacitor is charged DC.!
Tesla provides voltage and current impulse yoke does not play the role of a high-amperage This is not the inverter it's not like that.
I admits that he thought so that the current from the must take / from the field and not with the battery power multiplier
we are facing a big question mark: how to modulate the magnetic fle or if you prefer getting a standing wave
which account you do not look in these translations Ruslan no point A to point B. and you end up where you started.
do your best:
- get TL494 which will operate in the range of 2-3 MHz.Tesla breaker!
- ensure stable push pull optionally with stabilization The phase locked loop!
- electronic components, controllers and integrated circuits protected as the screen cover!
- perform independent and separate drivers low freg and hi Freg.ppv puls
sea and it sounds strange but recently I saw that the ground wire acts and performs the functions of stabilization to determine the direction of the phase.
in other devices running on a thin wire!
let me know if the message is clear or many words are skewed
