0 Members and 562 Guests are viewing this topic.
apecore
Quote from: NickZ on August 19, 2016, 11:36:32 AM
apecore:
  You mentioned:
  "Nick,
Thanks for the clearification about your "final" setup,.....  i have connected  it the same way...  my kacher is running well on the 28Turns,..(35volt)"
                    end quote.
   What rectifier diodes are you using, and are they heating up?
   Is your Kacher transistor heating up at that 35v voltage, with a heat-sink and fan on it?
   The reason that I've connected my set up the way that I have it now, is because I'm looking for the sync, similar to how Akula did it on his first video. Where he has the bulbs going just to earth ground and his output coil is not connected to anything but the bulbs.   I may change it later to another way of doing it. But, for now I'm trying to find the "effect" in that way.
   At the same time looking for the effect in the way that Roma has done it, without all the complicated gear, and yet reaching the same output, or better.  That's the best circuit to replicate, as far as I'm concerned, but we don't really know everything there is to know about how it works, as yet.
I use for load RURP3060.
And for kacher rectifier your version bur the 1520 ones (max 200V)
Each 4 diodes are mounted on radiator 4 x 4 x 1 inch
Nothing is getting hot
My kacher transistor consumes 2Amps (40Volts),...  it heats up yes... but i use no fan.
And my output coil gives no light in the 100W bulb.... (under load 21Volts)
Yoke drives at 12,4kHz (39% duty cycle at gates)
Total 7 Amps whole system
I will try the setups as you explained,...  i let you know what it wil do.
NickZ
  Nice. Thanks for the detailed reply.
  Good to hear that your rectifiers diodes aren't heating up.
   Maybe see if you can partially light a 100w bulb at the grenades' output coil, on just the Kacher's output, using 24v.
Place ferrite (flyback pieces) in the grenade pvc pipe, and ferrite inside of the Kacher's secondary side of the tube, also. Use a magnet on the yoke, try to further tune in that way.  It's easy.
  You'll see for yourself how the addition of the ferrite and magnets will raise the output by a lot.  By further adjusting and controlling the relation of those running frequencies in both HV, and the induction circuits.
apecore
Quote from: NickZ on August 19, 2016, 12:26:30 PM
  Good to hear that your rectifiers aren't heating up.
   See if you can partially light a 100w bulb on just the Kacher's output, using 24v, at the grenade's output coil.
And ferrite inside of the Kacher's secondary, also. Use a magnet on the yoke, try to further tune in that way.  It's easy.
60W bulb lights bright at start-up....  but goes out in a second,....  one piece of ferrite in kacher
apecore
Quote from: apecore on August 19, 2016, 12:38:25 PM
Nick,
I have best result with mounting 0ne ferrite piece.4 inchx 1/4inch on a plastic tube.... when it is positioned aa a bridge between kacher and grenade (inside)
allmost full 60 watt brightness
100Watt bulb very weak
so i will play one for a while
AlienGrey
"you could double the length for more EHT I suppose."
Are you saying that doubling the length of the secundairy tesla coil would give the same frequenty?
Or will it work on a harmonic what even will be satisfying in bottom line?
Half the frequency, If you don't know what your doing don't try it, but I put taps on mine every 1/4 wave so i can test out best option with out having to re wind it.
AG
