0 Members and 125 Guests are viewing this topic.
MenofFather
Quote from: apecore on August 20, 2016, 01:06:05 PM
Ok,...  strange but there must be a reason for it.
Another question about the inductor..
I wound my inductor 2 layers, but looking at the circuit drawings it seems that layer 2 has to start at the same point as layer 1?
Is that correct?.... i have layer 2 no wind back to the beginning of layer 1.
If your inductor 18-20 meters, then you can try wound in 3 layers. Nick corect say, how need wound. Wound woun layer, then go back, wound second, then go back with wire and wound 3 layer.
NickZ
  apecore:
  The inductor is wound only to the mid point of the first two layers of the grenade output coil width. Not all the way to the output coil like you have it. The Kacher secondary should not be more than about 3/4 of the width of the grenade coil, not twice as long.
   Every detail is important in this device, so maybe try to replicate it as accurately as possibly. As we don't really know what is important, and what is not so important.
   This is the video of the Ruslan replication that I'm working towards, again. It's the one with the same Kacher design.
https://www.youtube.com/watch?v=eFVsXUsn4Uo
   As far as removing turns from your yoke 6 turns coil, down to three turns.  Try 4 and then three turns without cutting the wire, and see which gives the best output at your bulbs.
    Did you see my last video, "Kacher/Grenade- sync? I posted a new video yesterday morning.
    By also removing both the positive and negative scope probe from the 0.47uf WIMA cap, the lights got even brighter than what I showed in that last video that I posted yesterday. As attaching those probes to the circuit affects the Kacher's sync operation.
But, the probes can be attached to the cap,  to read the induction circuit's values, no problem.
GeoFusion
Hi Nickz,
Nice man :) you managed to replicate the effect right there, first time I see it being done by Royer/mazilli Induction heater circuit.
Good job man keep it up. Now you can finally experience bit of the sensitivity of the device.
Hmmm you should try make a recording again next time and see what happens if you place you hand open
near the antenna but don't let it arc as we know it will make small holes and burns nasty.
Well lets continue experimenting :).
I might share something new soon.
Cheerz
apecore
Quote from: NickZ on August 23, 2016, 08:56:36 AM
  apecore:
Hi Nick,
thanks for explaning your setupo,...  despite he low vid resolution it is quit clear how it is functioning.
It is indeed true that groundings on parts do have influence.,,,  i try different setups because not everey drawing is same defined.
but on behalf of GF post i understand that yoy use not the mazilla etc.?
To bad you are not driving the kacher by the 28turns from the yoke at the moment,...  it will gain your output ...
This because it gets the 45Volts and also it can delivers several Amps if needed.... i have streamers of more then a inch...  (Oh no nothing but streamers)
In reaction of your suggestion to replicate al things exact as the original setup i must dissappoint you ;D
I need to play around on al parts of the setup in order to learn about its functionality
So i hope i can do sometroubleshooting if somewhere next year my powered refrigerator with the cold beers is not cooling any more.
I hope you understand?
My approach is that i will deliver the system step by step by testing and doing small modifications based on the systmes wich were created later in time.
Roma and also Ruslan have developed there ways of doing and learned also doing better (i guess)
This is a good oppertunity to get knwledge about its functionallity.
Thats also why my kacher is longer than usual,...  it has nodes,... and the wireis thicker..  (1mm)
But most important its driving on the desired frequenty now (did some long duration testlast night)
With yoke active i almost reached the 220Volts on a 60Wbulb.
So thats working.
Iwillcontinue nowchanging the inductor,... there are more possibillitys hearing you and MF....  important en fixed is i think the position.....  to create the correct timing i guess...
Number of layers is i think mor a amplitude issue,... as Tomtech mentioned something what i not yet understand about puh pulll frequenty and number of coil layers.
So this is it for now.
AlienGrey
Quote from: apecore on August 24, 2016, 03:10:16 AM
Hi Nick,
So thats working.
I will continue now changing the inductor,... there are more possibillitys hearing you and MF....  important en fixed is i think the position.....  to create the correct timing i guess...
Number of layers is i think more a amplitude issue,... as Tomtech mentioned something what i not yet understand about push-pull frequency and number of coil layers.
Interesting conversation starting here Apecore, I did notice you had larger than normal Katcher length how did you wind the device it in the end one full wavelength? with a node at 3/4 wave and 1 and 1 1/4 wave ?
also my original Katcher and waveguide made for tests.
Regards AG
