0 Members and 625 Guests are viewing this topic.
apecore
Quote from: Tomtech29 on August 24, 2016, 02:55:20 PM
Hi.
apecore
I mentioned Establishing the appropriate resonance point
See this section select the appropriate capacitor to the  (G coil):
https://www.youtube.com/watch?v=RdEnx6hfshQ&index=3&list=PLK7gxeQv5qT44ZM5TVnBW534ogPJnrXjg
- you will not see anything when the scheme reduces resolution !
See where the cylindrical shell I marked with a red line.
most likely There is disposed an aluminum foil ! and the tank LC is not grounded !
the rest of the scheme should agree so only the attention of the mount driver IR2110 is unlike other
It may seem complicated at first glance.
Tomtech thanks,
i see it now in the scheme,...
The mentioned caps in green etc..... no grounding of the G coil nodes....
I will give it a try thanks.
;D
N20Wolf
Quote from: Tomtech29 on August 24, 2016, 03:23:10 PM
Excuse me something I have a problem with editing entries and the photo is too large
Hello! this scheme  does not work. it is full of errors. Only time wasting
Tomtech29
N20Wolf
it's your opinion ?" this scheme  does not work. it is full of errors. Only time wasting"
check what is wrong :
https://www.youtube.com/watch?v=lQlQsR8hhiM
- from what I saw of the following formulas I repeated the system and waveforms are similar.
T-1000
Quote from: N20Wolf on August 24, 2016, 03:58:39 PM
Hi,
With basic knowledge on circuits design it is not too hard to see PLL, Push-Pull and Tesla Driver in circuit. The rest  of electronics is not so important to clone as long your circuit is making same scope shots.
Also when following wire connections to the coils - it seems there is fundamental error in all published circuits on series resonance to inductor. When retracing back from Ruslan Kulabuxov/Alexeew Sergey videos the 3/4T output of isolating transformer/yoke first have capacitor in parallel for parallel resonance then another capacitor in series going to grenade inductor for series resonance on same frequency. So the center tap of two caps in series is the input from the yoke 3T coil.
Also there is suspicion about how the grenade coil output was connected in Ruslan way - same 2 caps in series with center tap and 1 cap from two in series are going to the load.
So it is important detail which is missed out in published circuits.
Re-visit to Ruslan videos where you can retrace connections:
https://yadi.sk/i/KOHwNZ2HqmQuY
https://yadi.sk/i/Yh9qen8nqmQua
Sergey Alexeev - https://www.youtube.com/watch?v=YLhPFCOFAd0
https://www.youtube.com/watch?v=eywHbjStK4o
https://yadi.sk/i/yug9zEV6q26MA
https://yadi.sk/d/j469hfgKnCK53
https://www.youtube.com/watch?v=228uZWMgFv8
P.S> I hinted about parallel resonance+series resonance way back on 2013 as well - http://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg357338/#msg357338
scratchrobot
Quote from: T-1000 on August 25, 2016, 05:30:30 AM
Hi,
Your hinting since 2013 as if you know it all, i think you got some psychological problem.
