0 Members and 594 Guests are viewing this topic.
T-1000
Quote from: scratchrobot on August 25, 2016, 07:09:25 AM
Your hinting since 2013 as if you know it all, i think you got some psychological problem.
No problems at all with that as no one know it all.
And for each resonance type you may get into problem unless you do understand what you are trying to achieve in regards power in and power out.
Back in 2013 my goal was to minimise amps draw from the power source and maximise power given to the load. Then I see that in circuits above. Coincidence? :)
scratchrobot
Quote from: T-1000 on August 25, 2016, 08:19:41 AM
Isn't everyone here trying to achieve the same thing?
Are you saying you do understand what you are trying to achieve in regards power in and power out.
If someone is hinting something to me i assume they know it all.
Resonance doesn't give you more power out than you put in.
T-1000
Quote from: scratchrobot on August 26, 2016, 06:53:40 AM
It is first step towards unity. Then the secondary process adding towards overunity.
Thinking about Kapanadze style devices it partially is high potential electric field driving magnetic field of induction heater coil. Which doesn't couple to anything from the Lenz law.
AlienGrey
Quote from: T-1000 on August 26, 2016, 07:55:41 AM
I don't suppose you could give us a breakdown on how the Katcher and it's secondary function and again what happens when the katcher coil is excited could you ?
Best regards AG
AlienGrey
Ok, here we have an experimental do-dar-dit consisting of an NE555 running at 16.6 khz with resonance capacitors fitted on the primary consisting of 50 turns (yellow scope shot) and a secondary consisting of 200turns and resonance caps also scope shot purple is trig and light blue is secondary sine wave.
Notice the scope shot with single ended 'narrow width pulse driver' that produces a sine wave on the secondary and primary, notice the effect at resonance (and caps in parallel resonance on both windings ) the sine wave with no return standing wave is being generated ! Resonance no standing wave !! :(  Oh deary me I haven't wound that coil yet ;)
