0 Members and 577 Guests are viewing this topic.
NickZ
  Yes, well we all have questions...
  apecore:  You mentioned:
  "So i like to open this discussion  starting with the following basis question(s);
When we have a output coil length of 37.5 m,...
kind of standing wave do we need to create in this output coil?....
Has it to be the quarter wave of 2 Mhz?
                                            end quote.
   The problem has been that so far when tuning for the 1/4 or 1/3, or 1/2 wave frequencies.  Nothing in particular happens.
Which is the same point that Itsu got to.  And as each replication, and all the different versions are all different. And running at different frequencies. Which one of all to go with?  What truth to follow?
   AG says that I don't know anything...  that's true.  That's why I'm here.
apecore
Quote from: NickZ on August 26, 2016, 06:56:45 PM
Nick,
Shall i tell you a secret?
I know even less then you.....
NickZ
  As I had mentioned, I'm looking for the sync, and that is why I'm doing it the way that I'm doing it. To see what happens, next.
  So far, so good.
  Hopefully I'll be able to obtain some of the still needed components in the next few days. Then I can continue on using higher voltages, without overheating the rectifiers, or anything else.
  Tomtech:  So, we can also try the parallel cap placement on the 3 turns coils and test it out for ourselves. If it helps, use it.
What value are those caps supposed to be? Any idea?
  I don't remember seeing that capacitor on Ruslan's device schematic, like the version (TopRuslan7) I'm working towards.
AlienGrey
                                            end quote.
Which is the same point that Itsu got to  And as each replication, and all the different versions are all different. And running at different frequencies. Which one of all to go with?  What truth to follow?
I only know it's standing waves cus Arunus gave it away. Have you ever seen a winding that's wound like the hypocritical medical profession has as it's symbol well that's the secret in a way, it's used in the grenade coil.
I think the katcher is 20m yours should be 19 m same as the first winding on the grenade coil I think ;)
anyway we will soon find out, but note in my test circuit the tuning caps across the coil, it's in the Sergey circuit if you look.
NickZ
  Yes, well I test using a bunch of different caps, adding more caps like in Geo's round core device or more like his RMG device, didn't add anything for me on what I'm working on now. However, I have not tried the parallel placement on the 3 turns, as the version that I'm working on didn't have it, as far as I can see. Still, it may be worth a try.
  I suspect that a separate magnetic circuit is not necessary, if the circuit is made like the Poma self runner. The lower voltage and  frequency wave (standing or not), is produce by the same HV Kacher circuit.  It's the unknowns that bothers me on that device.
