0 Members and 58 Guests are viewing this topic.
AlienGrey
Quote from: Hoppy on August 30, 2016, 12:29:12 PM
Hi Geo,
Nice progress to show the 'effect'. Good work.
Taking your measurement of around 60V across your 300W lamp and given that a hot resistance in the order of 48ohms (for fully lit bulb), the max power being dissipated by the bulb works out at around 75W. However, as you comment, the lamp is perhaps half brightness to your eye, so the power dissipated is likely to be somewhat less than 75W. Your power supply is showing a delivery of around 120W, which seems about right. There is not a significant drop of current when additional bulbs are connected (although I do see a visual drop in brightness) because the current to the lamps is pulling the series resonant circuit off its peak tuning point, thus reducing the overall current to the lamps. In effect you have a semi constant current driver. Its important that you get a good handle on how much power the bulbs are actually dissipating in comparison to the power being delivered by the PSU. Also, from my experiments, bulb brightness v power consumption can be very visually misleading, especially when the supply frequency is much higher that the grid frequency. Good scope shots will give a much better understanding of the actual power being dissipated.
Hoppy! hello there, haven't seen you on this thread in quite a while, I hope all is well in the Hoppy household and sincerely hope you don't mind me asking and no offence intended but just asking, how is your own device coming along  any light at the end of the tunnel yet so to speak ?
If anyone is interested here is the Alexee v2 card I have the LYT file but not sure how to send it in on this software version I don't seem to have access to admin very strange.
The two chips to the right are TL494 and IR2130
I also have version 1, on a printed layout but not sure how i can copy it ;) as W7 does not support XP files such is life.
Tomtech29
HI All.
probably a little request for further investigation, as he will not take for further experiments
- I say this so that they do not know what is there to catch many of these "effects" but somehow (there is a likelihood of multiples)
See Video1 Geo:
https://www.youtube.com/watch?v=_-Mp0Si1juA
and this passage by Alex:
https://www.youtube.com/watch?v=kxkmxwThs70
already I tapped this phenomenon (while the approximation hand coil as if this has an impact on the increase in the amplitude) ...I do not know how to describe it in a nutshell.
"suppose primitive trick"
I do not recommend or nothing suggests and have no fellowship with me as bad as it's not important?(I try to share with you what I'm curious about) :D
Evaluate yourself judge / check
This element also bothering me with this film "aluminum cover":
apecore
Quote from: AlienGrey on August 30, 2016, 02:17:19 PM
AG,
Nice layout but i can't do much with it.
I can't make my own pritboards and therefore not all components are defined?
Connections are also not defined.
Don't you have the circuit drawings from both versions,...  i see that version 2 is quit different from the one i have.
Thanks in advance
Hoppy
No offence taken Alien. Lot's going on in and out of the Hoppy household which has kept me from experimenting. However, things seem to be hotting up now that Geo appears to be getting results. It appears that Geo has reached a point that Ruslan and other Russian experimenters have so far reached, which demonstrate the rather dramatic visual effect that the Kacher can have by controlling the power applied to the lamp load. Although I see nothing technically very unusual about this resonant effect, I do think that Geo has tuned his setup very well to maximise the visual effect.
There were several fairly serious build issues with my setup that I felt required a complete re-build, which is why I reported many pages back that I would only attempt this when I felt that I had a better technical understanding of how I could improve on version 1. I'm not really sure that I'm at this stage yet but Geo's latest well presented videos have given me food for thought and I am beginning to get a better idea of how the grenade and Kacher system is interracting to give the effect we see. If it is in fact possible to self run this type of setup, then hopefully Geo will be the first to achieve this as a member  of this forum.
AlienGrey
Yes indeed, thanks for the reply, I must admit I have made several mistakes myself and had to rebuild mine and scrap at least one unstable expensive driver card and abandon 2 other units built on bead board that did not measure up, lets hope we can all get some where in the next few months, fingers crossed.
