0 Members and 85 Guests are viewing this topic.
AlienGrey
Quote from: Tomtech29 on August 30, 2016, 03:46:36 PM
HI All.
probably a little request for further investigation, as he will not take for further experiments
- I say this so that they do not know what is there to catch many of these "effects" but somehow (there is a likelihood of multiples)
See Video1 Geo:
https://www.youtube.com/watch?v=_-Mp0Si1juA
and this passage by Alex:
https://www.youtube.com/watch?v=kxkmxwThs70
already I tapped this phenomenon (while the approximation hand coil as if this has an impact on the increase in the amplitude) ...I do not know how to describe it in a nutshell.
"suppose primitive trick"
I do not recommend or nothing suggests and have no fellowship with me as bad as it's not important?(I try to share with you what I'm curious about) :D
Evaluate yourself judge / check
This element also bothering me with this film "aluminum cover":
Hi Tom yes this looks familiar a layer of copper with a small gap ? 10 m ccw  10m cw, 5m ccw 5m cw 2.5 m ccw 2.5 cw ? or have you used different lengths ?
Regards AG
NickZ
  Hoppy:
  I was starting to miss our house detective, as well as a few others, like Verpies, Itsu, and some of the other old timers.
Oh, it's good to see Tomtech posting again as well.
   I would tend to agree with your analysis of Geo's lastest video device.  But, possibly the important thing at this time, regardless of bulb brightness or it's input to output factors, is to locate the effect that actually makes it self run.
In Geo's words,  "that will come".  I hope it does.
   Geo's new push-pull driver looks fairly simple to build, unlike Ruslan's latest driver.  So, I'll probably give something like that a try, also. But, for now my Mazilli is up and running well.
   It's gotten harder to detect the actual "effect" on my device, from just the addition of one voltage onto another.  Since the bulbs are lighting much brighter when the Kacher is also on now. Unlike before, where there was no change in brightness, or even a dimming of the bulbs, at times. As the Kacher's input now comes from the yoke secondary coil, and it much higher voltage, and intensity. That's why I was working with lower voltages at first to see if I could light more bulbs, than you normally would expect with that low a voltage/amperage. But, if that input source for the Kacher is drawn from the induction circuit, is used for looping back to the Kacher circuit's input without affecting the draw, that would be something.
  Anyways, I'm seeing some interesting "effects", at lower than 100 watt loads.  But, my bridge rectifiers just melted 3 solder points, all at once. So, I'm looking for some stronger diodes, as my order of MUR1560 were not available.
My device make no ringing noise, at this point, and I hope that it stays that way. Nice and quiet.
  Good to see you back.
Enjoykin2017
Hi Geo !!
Nice progress ! Are you ready for a moment of TRUTH ??
Loop back your generator and see what you will get.
Will be important for you to make some oscillograph meassurement of output tension, current and envelope. Also you can try boost capacitor value in range 2x or some higher if you have more WIMA capacitors.
I wish to ask you for parameter of your Earth-Ground conductor ? As massive is that conductor it is better because more conducting electrons device suck from the ground.
Best wishes
enjoykin2017 !!
All: A NEW AGGREGATE STATE - RADIANT MATTER !!
Well many questions will be answered to us if somebody get luck and find Tesla´s pivotal lecture "THE DISSIPATION OF ELECTRICITY" from 1892 year.
According to Genius John Ernest Worrell  Keely he used 3rd LEVEL OF MATTER DISSOCIATION (dissociation on smaller matter particles from core particles) and also gave frequencies for it.
Also like Ed.Gray said in "SPLIT THE POSITIVE" or in my interpretation "SPLIT THE CORE"  - ATOMIC CORE´S PARTICLES".
RADIANT MATTER PARTICLES SHOUD BE IN THE ATOMIC CORE or precise in the internal sub-structures of MAGNETIC DIPOLE MATTER which exist in the core. This magnetic mass matter isn´t magnetically compensated (it means it exist like dipole matter in different amounts), and she is a real source of Magnetic Field Matter, or in combination with Electric mater (photons) short living Electromagnetic Field Matter. For me any FIELD is absolutely material (has mass in no motion state ) - not like some imaginary wave/s from main stream science lies. !!
Remember simple fact that only THE MATTER CAN BRING A FORCE- not energy like MSM science assert (lying !!).
The main problem - filtering RADIANT matter particles (RADIANT MASS) from Magnetic matter particles (dipole matter) and Electric matter particles (photons), Tesla had succesfully solved with MAGNETIC DISRUPTOR SPARK GAP (Very strong U-shape permanent magnet), and got a PURE STREAM OF COLD LIGHT - LUMINOUS RADINAT MATTER as a NEW AGGREGATE STATE !!
As we now know from Tesla this new aggregate state RADIANT MASS can also exist in long living Radiant clusters of COLD LIGHT, forms which Tesla moved with own hands through his labaratory and further.
All experimenters should make strong attention on Effects of RADIANT MATTER !!, - from Gary Vassilatos book "The secrets of Cold War Technology ".
Best wishes
enjoykin2017 !!
Hoppy
Quote from: NickZ on August 30, 2016, 06:29:44 PM
Nick,
Yes, if anyone can succeed through dogged persistence, I reckon the first is likely to be Geo.
Its interesting observation to me that Geo's configuration and tuning allows him to connect several bulbs without an apparent substantial increase in supply current or reduction in visual brightness. Given that he demonstrated clearly the sensitivity of his setup to hand capacitance around the Kacher, resulting in big changes to brightness, I would have expected a greater variation of lamp brightness resulting from increased lamp loading. I would like to invite our technical experts to chip in and comment on this as to whether they have an explanation for this.
Meta
I told you before, electrostatics is where its at.
0D = 3D
0D- electrostatic- Radiant from and to the center.
1D- Electric
2D- Magnetic
3D- Gravity- Radiant from and to the center.
OR, counting from 1
1D = 4D
1D- Electrostatic- Radiant from and to the center.
2D- Electric
3D- Magnetic
4D- Gravity- Radiant from and to the center.
