0 Members and 58 Guests are viewing this topic.
Jeg
Quote from: T-1000 on September 02, 2016, 05:52:57 AM
And now when you inject voltage potential spike from the Tesla coil when the current is maximum on the 3T coil they merge into output power P = U * I even when the sources are from separate inputs.
If you go like this, then you will just end up with a conventional power adding between the different sources. No gain here.
T-1000
Quote from: Jeg on September 02, 2016, 06:16:53 AM
Well, you probably are forgetting what it takes almost no power to create millions of volts EM field. And when merging that into output power with different source which create current... This is where it is getting interesting with open systems :)
AlienGrey
Quote from: T-1000 on September 02, 2016, 05:10:10 AM
The Micro-controllers are going crazy after Tesla coil EMP field. Would be most compact option if they wouldn't... :)
If the pulse is Longitudinal it will destroy them in a short time! the same goes for Bankster's Evil human chipping plan and cancer tumours using a magnetic toroid as was recently shown on BBC news and then hushed up by the interviewer!
conico
You can use LMC555 is able to osccilates  up to 2 Mhz maybe more, at 5volts
sorry is for this post:
''Guys i'd like to move to faster switching and i am looking for pwm controller and Mosfet driver able to run up to 2 or 3 MHz. Do you have any idea to experiment with? Any published circuits?  Thanks ;)
conico
Quote from: Jeg on September 02, 2016, 04:20:29 AM
@AG, T1000
This can be usefull with LMC555 up to 2 Mhz supply just 5v.
