0 Members and 672 Guests are viewing this topic.
NickZ
  Yes, well I don't have any idea what that motor cap's value is, nor do I have one like it.
  I do have a 2100v, 0.90uf microwave capacitor.  I'll put that on and see what happens. But, there's no rectifier on the grenade output coil, like Geo has on his set up. As I placed the full bridge on the 3 turns capacitor.
   I do have the 0.1uf parallel cap on the grenade output coil as was shown on Ruslan's diagram, already.
   Funny thing though, now neither the ferrite inside the grenade former tube, nor the magnetite on the yoke make a difference, only to drop the output. This would normally indicate that I'm at the best frequency, without them.  But, I can't tune the device, like did previously.
   Geo: What value caps are you using on the rectifiers.  Are the brown caps the 0.33uf?  The motor cap is?
Jeg
Thanks for the 555 idea Conico. I'll use it with a mosfet driver. See here with independent frequency and pwm control. http://www.overunity.com/8597/solid-state-orbo-system/msg234095/#msg234095
I missed 555's simplicity. :D
AG it is not for a push pull. It is for a single mosfet switch just for playing at higher frequencies. What do you think? With an lm338 for providing up to 5A to the mosfet driver, would it be enough to charge quickly a 2500pf gate cap? I want it mostly for frequencies up to 500Khz, but also frequencies like 2MHz will be used.
apecore
Quote from: NickZ on September 03, 2016, 11:48:45 AM
   apecore:
   I connected the output of the load of bulbs to the 0.47uf capacitor. Also with the 28t coil yoke coil connected to the grenade's output coil.
  The results:
   The lights (3  120v, 100w bulbs) light fairly bright, but not as bright as when on the output of the grenade coil.
   However when connecting the full bridge which feeds the Kacher's input to the 3 turns coil, it kills the lights.
   I reversed the polarity of the bridge at the cap, still no difference, no lights.  I don't know why, as there is enough power at the cap to run the Kacher circuit, also, but when I do it kills the lights. Even it's only a single 25 watt bulb on at the time. Plus the Kacher circuit will NOT run off of the 3 turns coil/capacitor connections, either.
   So, similar results?
Nick.
I tried  different setups according the setup you posted.
No result.
I have aso a lot of questions,,.... starting with the first one,...  is the circuit you purpose to be the one actual?
I hope ( and it is not a ment disrespectfull) that Geo will post some more details about his confuguration,...... we guess now if we are doing the right thing or not.
It is as i see in the last post very frustating that we are spending a lot of effort in doing things witout knowing if we are doing the same.
Sorry guys but i think we could share information in a better way...( i don't want to blame someone,...  it is as it is and we are all part f it)
So if GeoFusion could confirm the requst from Nick about his drawings more in details ,..... it would help a lot in judging the results for al of us and will effect even in general.
And i mean by that even mentioning resonance frequentys, caps and coil values.
The more to compare the more there will be explanable.
So please lets start with the drawings as Nick ask for confirmation...
NickZ
  apecore:
  "I have aso a lot of questions,,.... starting with the first one,...  is the circuit you purpose to be the one actual?"
        end quote.
    I had posted what I just did, so I think that the answer is yes.
    But, I'm not proposing anything, I'm just trying out Geo's wiring method, as it's his 2016 schematic I posted. Which was updated from the previous version of Ruslan schematic, which was first redrawn by Abrahim.
      So, I'm still at it.  I just added the microwave cap in parallel to the output coil, and noticed no change.
      No way to make the Kacher light up or work from the 3t coil/capacitor now. I still don't know why that is, but I'm working on it.
If you figure out what needs to be changed in order to make the Kacher work in that way, off of the 3t coil, let me know.
   EDIT: Perhaps Geo can connect his Kacher's input to the grenade output coil's rectified output, and tell us if he can run the Kacher in that way, instead of from the PS.  He should be able to do so, unlike my trying to run the Kacher off of the 3t coil/cap.
Hoppy
Quote from: NickZ on September 03, 2016, 04:39:24 PM
Nick,
I suspect that its not the Kacher directly driving the bulbs to increased brightness as we see in Geo's video. I think its the Kacher HV affecting the push-pull, in which case you may not get the same effect as you are using a Mazilli yoke driver.
